Question about Sony Ericsson T28 World Cellular Phone
The phone reads No Access and nothing works ecept that the battery charges and the time is displayed
By blackberry flip turned off in the middle of a call and I have not been able to to turn it on since. I changed the battery and that did not work. Any ideas?
it may be that battery is faulty, and is not charging.
A standard cellphone battery can support a charge from near empty to full about 300-500 times. after that, the charge is not 'filling' the battery, and it is drained quicker.
You can test the ability of the battery to hold a charge.
1. Plug the cell phone into its charger and plug the other end in to an electrical outlet. Allow the battery charge to full capacity.
2. Press and hold the power button on the cell phone to turn it off. Let the phone power down and remove the back cover to access the battery.
3. Remove the battery and observe the label for the voltage. Most cell phone batteries are 3.4 to 4.5 volts.
4. Turn on a multimeter. A multimeter tests current flow in voltage and amps and also resistance in a circuit. Place the black test probe on the negative battery contact and the red test probe on the positive battery contact. The contacts are on the edge or bottom of the battery and should be marked negative (-) and positive (+).
5. Place one test probe on the left terminal and one on the right, if the battery terminals are not marked. These are usually the correct terminals and the meter will show a positive reading. If the meter shows a negative reading, move the left or right probe to the middle terminal until one pair shows a positive reading.
6. Read the display on the multimeter. The voltage should be the same or a little higher than the battery label due to the fact that batteries hold an additional charge above the full charge mark when they have just been charged.
You can go to your local mobile store, and ask them to try another battery in your phone. if it works, great, you just need a new battery.
If not, well, the phone might have water damage, could have a circuit shorted out or something unusual. eitherway, if the phone doesnt turn on, you need to take it to the vendor, who has resources to test the equipment.
make a friend with someone who also has a Blackberry 8220, maybe you can try their battery for free, and if they arent looking, pull a switcheroo!
Mar 08, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
My mobile problam is no display and no working
davidscott3 . I fully sympathise, dheerajsi506 , because the same happened to me today , 14 June 2010 .
First I put the SIM in the wrong way round.Then I forgot to load the battery . Charging the N 1661 went OK . Then I had no screen display no matter how many times I pressed the Power key in red . I tried holding it down a few seconds , nothing .Read the small manual several times . It does not always explain fully .
Eventually I went to my local Vodafone shop.The guy got it going in 2 seconds ! He did the same as I had tried .I have found before that my hands seem to interfere with new gadgets .It now works just fine .
I suggest you ask someone to try for you ,to get your luck back .
Jun 14, 2010 | Nokia 1661 Cell Phone
Nothing shows up in the display. This has only been recently after a power glitch. The display lights when a call is made or received.
I unplugged the base unit from the wall for more than 10 minutes. Sometime after I plugged it back in (not immediately)the display re-appeared.
Nov 16, 2009 | Panasonic KX-TG2631 Cordless Phone
All functions except picture taking work on camera
Problem with lens assembly. No user solution. Contact service.
Aug 17, 2009 | Sony Cameras
Screen works when charging but then nothing!?!?
Yes the software is the problem. Try updating your firmware. It can be downloaded.
Jul 08, 2009 | Sony Ericsson w580i Cellular Phone
I just opened a new motorola razr v3 mobile phone and have put in the battery and am trying to charge it but there is absolutely no signal at all to say it is charging. It has been charging for about an...
hi,there.. what's happen with your new phone is normal and nothing to worry about it... usually at the manual book from phone factory the recommend to charge battery for first time use is about 4 hours. after this next time if you want to charge battery i suggest only if only left 1 bar battery indicator at your cell main display....
Feb 03, 2009 | Cell Phones
MY CELL PHONE IS BROKEN
pull the battery out,
Remove your SIM card & clean the phone.
insert the card, charge the battery & repower
Oct 22, 2008 | Radio Communications
Hello I got a Motorola Razor "brand new" from e-bay.....
reflash the firmware on the phone or service it
Dec 07, 2007 | Motorola Mobility RAZR V3
Not charging
i think ur phons circuit is short .so thats why
Nov 27, 2007 | Nokia 5500 Sport Cellular Phone
Sony Ericsson T28 World Cellular Phone Logo
96 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
