Question about Sprint Hitachi P300 Cellular Phone
I have filmed onto a mini disc. I then watched the recording and it was fine. I then finalized the disc and now I can't play the disc. I get a disc error message. I have tried to play it on the camcorder and also on 2 lap tops
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Anything I have recorded onto DVD from TV wont play on any other machines. It will only play on this machine I recorded on. It is the same make and model mentioned here.
If you're not using DVD+RW blanks (VERBATIM work fine), then try them. DVD-RW blanks will not play on any machine but the one that recorded the disk (according to the manual.)
Nov 24, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I cant seem to finalize the mini dvd on my canon dc330 cam corder
Make sure you are in the mode to view the videos you recorded and make sure the camera is plugged in to the power supply, then the finanlize option should be available
Sep 14, 2009 | Canon DC330 DVD Camcorder
Sony Handycam says movie recording disabled. How did this happen and how do I undo it?
Follow this procedure to troubleshoot when Recording disabled is displayed by the camcorder.
  1. Verify the disc being used has not been finalized. It is not possible to record additional video on a finalized disc.
  2. Attempt to record on a different disc.
Aug 02, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Viewing pictutes
Please finalize mini dvd disc if its full or when recording is finished.
Without finalization dvd will not be playback anywhere except camera.
DVD Finalize option is available in camcorder Menu.
May 11, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Transfer my minidv camcorder film onto DVD
You need to download the movie to a computer and store it in a video file. Then you should be able to use a software program to burn it to a DVD. I use a TIVO for watching and burning my videos. You don't need a computer. You save the video by recording it to the TIVO's hard drive then after it is on the drive you DUB it to an empty DVD-R disc.
Jan 24, 2008 | Panasonic NV-GS17 Mini DV Digital...
Playing back footage on pc
mini DVs sometimes can't be access using usb interface, try to look if u have a firewire interface, be sure your laptop supports IEEE1394. power dvd is the best player for dvd files. -r means recordable, not rewritable (rw). if ur not familiar with video editing, you may not be able to burn it to disc, but you can play and watch everytime.
May 17, 2007 | JVC GR-D250 Mini DV Digital Camcorder
DVD Camcorder appears to have erased disc mid record!
I know it won't play in a dvd player till it is finalized. Leave it in camera mode, hit menu, and scroll down till you see the option to finalize. If you finalize it, it should play in a dvd player. I am having a problem with my camera(same model) where it won't finalize the disc. Any help out there?
Nov 16, 2006 | Samsung SC-DC164 DVD Camcorder
Sprint Hitachi P300 Cellular Phone Logo
15 people viewed this question
Top Sprint Cell Phones Experts
TekkiDave
Marvin
Marvin
 Mikey
Mikey
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
