Question about Sharp Office Equipment & Supplies
Sharp 4:3 projector shows blue at 16:9
I have a Sharp projector that is native 4:3. I have been displaying 16:9 for 9 months. Now see blue at top of screen in "unlit" area.
  • 2,237 Answers
If it's a lcd projector, the polarizer on the blue lcd is fried due to excessive dust and heat. when the lcd is blacked out, the light reflects back through the polorizer, causing more heat. you'll have to send it to a sharp service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Dec 16, 2009
Testimonial: "Sounds like very solid advice"
Frequency is out of range
What are you sending to the projector? The ES4 is a native S-VGA resolution machine. This means it has a 4:3 display panel with a pixel count of 800x600. It will accept higher resolutions, but there may be some combinations that are 16:9/16:10 that the projector isn't happy with; specifically 1080p @ 24/50/60Hz. It maxes out at 1080i 60Hz. So if you are connecting a laptop with a native resolution of 1920x1080 then the projector will struggle.
The other thing you should do once you get a signal working on the projector is to set the laptop output to the projector's native resolution. This will give the crispest image.
Toggle the laptop display (Fn + appropriate F key) so that laptop screen is off and the projector is the only thing getting a signal. Then right click on the Windows desktop area, and then select Graphics Properties from the sub menu. Change the settings from there.
Sep 08, 2014 | Sony VPL-ES4 Projector
Toggle the laptop display (Fn + appropriate F key) so that laptop screen is off and the projector is the only thing getting a signal. Then right click on the Windows desktop area, and then select Graphics Properties from the sub menu. Change the settings from there..
Epson adjustment
The projector has a 4:3 display panel (1024x768 pixels). When you send information to display in 4:3 mode, the picture spills over the top and bottom of your screen.
When you send stuff in 16:9 mode, the projector shows this on the screen as 16:9, but the panel area is still 4:3. This can't be altered. So the unused part of the 4:3 panel above and below the image still bleeds some light through. That's what you are seeing.
You can mask some of this effect by using light absorbing material such as black velvet above and below the screen. Alternatively you can replace the projector with one designed for home theater use which has a 16:9 panel to match the shape of your screen.
Sep 05, 2014 | Epson EX51 Projector
Ballast uart error
The ballast module controls the lamp operation. There is a problem with that module
Nov 27, 2013 | Vivitek D732MX DLP Projector, 3200 ANSI...
Hello, I cannot change my picture from 4:3 to 16:6. The mode "change size" is not working. I cannot stretch the picture. Wolfgang, Germany w
hi,
You have to set the out put video format of your dvd player also to 16:9. For that go to the menu of your dvd player and serch for video output seting and set the output as 16:9.
Even if you select 16:9 option in the projector if the video out put of the dvd is 4:3 , then the projector will automatically change to the 4:3.
ok
Jul 30, 2011 | Sharp Educator Series XR-10X DLP Projector
How we can connect a lap top with sharp x
Just use a VGA to VGA cable and in the Display properties set it as a second display with the native (most likely XGA) resolution.
Nov 25, 2009 | Toshiba Satellite A105 Notebook
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    427 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
