My dryer seems to spin but there is no heat! is there any fuse I should replace or should I start looking for a new one. The current one is about 8 years old
    Scholar:
  • 66 Answers
If your not getting heat but you are spinning your problem is either the thermostat or the heating element. Both are located in the rear of most dryers and can be easily replaced. It shouldnt be too expensive to replace them yourself and its pretty easy to do. However finding the correct parts for a machine that old may be difficult. Check with an appliance parts store in your area and make sure you have the model number of your machine ready.
Posted on Dec 12, 2009
SOURCE:
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Dryer is not heating up, but will tumble
Hello there and thank you for choosing fixya
This is a fairly common issue with dryers
There are only a few items that will make a dryer not heat Depending on your model
The first is the thermal fuse
To be fair, this failure's usually not the thermal fuse's fault, but the real cause lies in a partially (or completely) clogged dryer vent system. In those cases, the thermal fuse is just doing the job it was designed for.
Thermal fuses, or thermal cutoffs, are small electrical temperature sensitive 'switches' designed to interrupt electrical current flow when heated to their specific rated 'trip' temperature.
Unlike a thermostat, which automatically resets itself when the temperature drops, thermal fuses are more like their cousins, electrical fuses, another single-use type device that can't be reset and must be replaced when it fails or is triggered.
In addition to their legally mandated application in modern clothes dryers (since the 1980's), thermal fuses are used as safety devices in other heat-producing appliances like coffee makers and hair dryers. They disconnect the flow of current to the heating element in case of malfunction (such as a defective thermostat or clogged dryer vent) that allows the temperature to rise to dangerous levels, possibly starting a fire.looks lke thistbirdfan1_81.jpg
and the last thisn is the heating element it'self
most of them look similatr to this one below but once again yours may be differenttbirdfan1_82.jpg
May 06, 2011 | Dryers
I have a whirlpool lgq8611pw2 gas dryer. it has stopped producing heat. gas supply seems fine and other gas appliances work fine. Took front lower cover off and blew out dust> pulled and replaced...
go to this site..
I think the first item is what is bad. here's where to start.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-5-654402-/new/Whirlpool-Dryer-not-heating-LGQ8611PW2
Jan 07, 2018 | Whirlpool WGD5200TQ Gas Dryer
My dryer spins but does not heat up. What should I do?
It's most likely a thermal fuse (some call it a thermostat) which has overheated and opened, stopping the current to the heating coil.
These are usually accessed by pulling off a panel on the bottom front or removing the back.
There are usually 3 of these devices with two or sometimes 3 wires plugged into them. They are about the size of a Chicken McNugget. One is the thermal fuse, one is low heat thermostat, other is high heat thermostat.
Check these for continuity with one of the wires going to it unplugged. If the meter shows no current going through it, it is bad and needs to be replaced.
More info, let me know.
Charlie
Aug 28, 2009 | Roper REX4634KQ Electric Dryer
Clothes dryer will not start
sounds as if your motor has tightened-up or seized from heat and age bearing failure which it would cause excessive current draw at start-up if you can access the motor unplug unit then remove belt and spin motor pulley is should turn freely and coast to a stop if it seems tight the bearings are dried out
Jul 12, 2009 | Whirlpool Dryers
GGQ9800PW1 How can I remove the back panel? My dryer spins but does not heat. I've been advised by a reputable parts/replace place how to test the thermal fuse. They said to remove the back panel as if...
Newer models have access through the front lower panel. Removing the panel will expose the t-stats and all other parts. Remember to disconnect all power to dryer before servicing. Disconnect the wires to the thermal fuse and join them together. Connect dryer and start, if it heats up then your fuse is bad. Costs about 10 bucks.
Jun 30, 2009 | Whirlpool GGQ9800L Gas Dryer
White westinghouse
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Dec 11, 2007 | Dryers
New Dryer Belt
The switch on motor is sticking or broke. You can try cleaning lint from motor and around switch. (Box with wires going to it on motor.) If this doesn't work you probably need a motor.l
Nov 07, 2007 | Amana ALG331RAW Gas Dryer
Maytag Performa PYE2200AYW - not working
Yes there is a fuse in the dryer. The black circular thing is a high limit thermostat. Beneath it is the thermal fuse. It is smaller (dime size) and is mounted to the right side of the heating element housing. It is alittle tough to see and get at. You must use the original Maytag part kit.It comes with a new high limit therm. and fuse.
Oct 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
