Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Phillips mod.#55pw9363/17f i have sound but no picture no av number no display at all on any input dvd cable satelite only soun no picture??
  • ccmengineeri Dec 12, 2009
    how would i determine if a capacitor is bad, is it obvious. i am an electrician so i have a vom and some troubleshooting skills but limited experience with component repairs
  • Philips Master
  • 5,138 Answers
These TVs are well known for bad capacitors near FBT fyback Transfomer 100uf 160v 200uf 250v, alot of poor solder connections on power supply board or Bad high Voltage Trippler Block
Posted on Dec 12, 2009
  • ladywinn
    ladywinn Dec 12, 2009
    Start out with Checking your Hori output Transistor near FBT it might be shorted your high voltage is not coming up Capacitors if you are lucky they will puff up on Top others will either be leaky on bottom of them or just will not hold charge when turn theres also a 1ohm resistor that feeds to hori output Transistor that has been know to open You have a Focus/screen drive Block it will have 3 controls on top for Focus to each Tube R/G/B and 3 under them for screen drives to each Tube R/G/B thats the part thats replaced alot Go online to Encompass Parts type in your Model number they list 587 Parts to this TV Look For Part number for Trippler Block they do go bad alot, you can also look up Mats Electronics 1-800-628-1118 ask them to send you a catalog book! I understand none of your Tubes are lighting? resolder all the pinns on your FBT and It could be Bad thats produces all the voltages to circuits.
Cant get sound using digital optical cable with pd3000
IT DOES NOT LOOK LIKE THE RECIEVER HAS A OPTICAL INPUT YOU WILL HAVE TO USE AV CABLE STERO RIGHT AND LEFT FROM TV TO RECIEVER THEN CONNECT BLUE RAY AND GAMING SYSTEMS WITH THE AV CABLES
Feb 19, 2014 | Pyle PD3000A Amplifier
Av can connect to DVD but unly a blue background comes up; no vieing, no sound??
ensure that the AV and sound cables are well connected. confirm that you match the terminal inputs with the colours,also confirm its in the right input channel. the yellow cable is meant for video and if it doesnt display try another yellow terminal
Sep 17, 2011 | Televison & Video
How do I connect my dvd recorder/player to my TV
RCA Plugs from your DVD to tv must correspond to colours, and must go to AV 1 input on the tv and then from your satelite the RCA Cables must go into the corresponded colours on the dvd player :eg. (Yellow to Yellow - Video) (Red to Red - Left Sound) (White to White - Right sound)
May 09, 2011 | Televison & Video
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
How do I conenct player to tv
  1. Yellow wire is picture and the 2 red is sound
at the dvd player plug in the picture wire by av out, at the tv plug the yellow wire in av in.
The sound is the same sound out at the dvd player look for a L R this means left and right at the tv there should under av in next to the picture wire you pluge the soun in
hope this is clear to you
Jan 04, 2009 | RCA DRC220N DVD Player
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
SAMSUNG
So you want to connect your red and white cables from your satelite box output to the receiver's auxillary inputs or TV inputs.
OR
Red and White from your satelite output to an input on your TV, then another red and white from an output on your TV to the recevier. This way you can have sound from the TV and use the receiver when you want things to get louder. You also need a yellow single connector from the satelite to the TV to carry video. If you are using a coax cable from your satelite to your TV then you are cheaping yourself out of picture quality.
Apr 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Hook me up, please!!!
Not shure what you or asking, if how to hock this up well , it's so easy, I've never though about it.
For the bell express hook it up with av cabling to input 1,
For the dvd hock it up at input 2 with av cabling again
for the gamming system well input 3 or the front input's with it's supplyed cabling.
To watch ether or other source redecrect your ptv to soource solected to watch witch source your using, exc for satelite bring the source on your ptv to input 1 and etccc..... for the other sources, I hope this helps
Regards
What About Bob
Timmins, Ontario
Home of Shania Twain
Dec 28, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
