Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire model glrs267zcwi side by side. Crushed ice comes out when either the crushed or the cubed button is depressed. How to fix it please?
    Scholar:
  • 66 Answers
If its stuck on crushed your selector switch is probably broken. Being as its and electronic switch you cant really fix it yourself. You could replace it but it requires taking the entire door off of the refrigerator and most times even a repairman wont go to all that trouble and would just replace the door. Recommend you call a repair guy to come look at it as theres not much you can do by yourself on it.
Posted on Dec 12, 2009
  • 744 Answers
It sounds like the water line to the ice maker is partially obstructed (probably semi-frozen) and the unit is making smaller than normal ice cubes. This causes the ice ejector to "shatter" the smaller cubes, producing the appearance of crushed ice.
The easiest thing to try is make sure the water line connection inside the freeezer isn't frozen. A hair dryer can be used to thaw the inlet to the ice maker, but just be careful. Remove some of the product in the compartment so you have enough room to work.
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Apr 10, 2015 | Frigidaire FRS3R5EMB Side by Side...
Why am I getting crushed ice when I requested cubes
Hello friend, thank you for your post!
I understand that you are receiving crushed ice even when you request cubed ice. It could be an issue within your control panel or solenoid. Since it could be any one of these under lying issues I would recommend having a technician come out to properly diagnose your appliance. Hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
Can I disable my crushed ice maker
Good Morning Friend,
You want to disable your crushed ice maker on your Frigidaire refrigerator, model# FRS26R4A. You will need to push the "Cube" button for the ice dispenser to stop dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire FRS26R4A Side by Side...
We emptied ice bucket to fill cooler. Now all we get is crushed ice and not cubes. I can switch buttons from crushed to cubes but still get crushed. Did we do something wrong when I pulled out ice bucket...
There is a metal rod under the ice bucket. This rod sticks out from the back of the bucket. Where it inserts into the ice shelf, you will see a small square hole. This is what changes it from crushed to cubed. It is an actuator that moves the rod to allow cubes to come out. Stick a screwdriver into the square hole and move the actuator up and down. Then reinsert the ice-bucket and that should fix the problem. Hope this helps.
Mar 24, 2011 | Frigidaire FRS23H5AS Side by Side...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker stuck on ''crushed'' ice
i think it's simpler than that. there's a plastic gate that snaps UP for cubed and DOWN for crushed.
When you remove the tray, set it to CRUSHED, BEFORE putting the tray back in place.
Nov 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
247 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
