Question about GE Refrigerators
Noisy sound behind icemaker assembly, loud motor noise
  • 21 Answers
Sounds like evaparator fan ,
Posted on Dec 13, 2009
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
Whirlpool top-freezer refrigerator makes loud noise
Do you think it is the fan in the freezer or could it be the water valve when the icemaker is filling?
Nov 27, 2012 | Refrigerators
I have a kitchen aid dishwasher KuDR01TJBLO noisy when draining
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | KitchenAid Dishwashers
My side by side has a LOUD whining noise coming from behind the freezer area that lasts for up to an hour.
This noise is most likely comming from the fan motor. The main board often causes the fan to be noisy but it could be a bad fan motor as well. http://www.appliance-repair-it.com/refrigerator-fan-motor.html
Sep 10, 2010 | GE Refrigerators
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from JD-21 ice maker
Usually a stripped gear or a bad icemaker motor. Remove the icemaker front cover by using a flat screwdriver to pry it off between the bottom of the icemaker and the cover. Inspect the icemaker to see if the large white plastic gear has any broken teeth or is cracked in the middle. The motor is in the 10:00 position of the white gear. If the gear is ok, and the noise is coming from the motor, replace the motor.
After unplugging the refrigerator you can remove the motor assembly by removing three screws in the mounting plate, and then two screws holding the motor on. The parts house also sells the complete icemaker, however your refrigerator is already 29 years old if I am reading your model number correctly. Good Luck, Appliance Specialists
Jan 01, 2010 | Kenmore Refrigerators
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Heater/ac only works on high...and on high it's extreamly noisy
sounds like relay to me but what blew it, most likely dry bearings on blower motor causing your noise clean oil fan motor install relay
Dec 27, 2008 | 1996 Chevrolet K1500
Intermittent Loud Whirring Noise
sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Sep 30, 2007 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
