Question about Onkyo HTR500 Receiver
S-video from computer through receiver
Is it possible to hook up my laptop through my Onkyo receiver and have it display on my TV? I can't seem to figure it out.... Thanks!
    Problem Solver:
  • 18 Answers
Yes, if you use the S-Video output on your laptop to the input on the receiver, then another S-Video cable from the Monitor Out port on the receiver to an S-Video port on your TV. Then select the appropriate source on the TV and receiver.
Be reminded that this receiver will not convert the signal from S-Video to composite video (the yellow cable) nor from composite video to S-Video.
Also be reminded that S-Video will pass only video, not audio. You need a seperate cable to go from a 3.5mm headphone stereo jack to 2 RCA composite audio plugs.
Posted on Jan 28, 2008
HDMI flashing screen on Onkyo TX-SR674 receiver need advice on how to solve this problem
Hi Zach, you can try the following reset as this might be a glitch in the processor.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Feb 21, 2015 | Onkyo TX-SR674 Receiver
How do I hook up my Onkyo receiver to my dish network box?
Take the cables from the receiver to the tv and connect it to your Onkyo where it says "in", then take another cable and run it from your Onkyo receiver where it says "out" and connect it directly to the tv. Make sure you cycle the inputs on your receiver and tv, so you get sound and video.
Daniel Busa
DISH Network Customer Service
Jan 05, 2011 | Onkyo TX-SR505 Receiver
Display doesn't light up on Onkyo TX-DS595 reciever
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown
Dec 04, 2010 | Onkyo TX-DS595 Receiver
Tv soundbar with a 5.1 receiver
The Onkyo has a center channel pre-out that you can connect the sound bar to. How does the sound bar connect to the TV? Is it two rca jacks, 1 red and 1 white or black? What brand and model is the sound bar?
May 16, 2010 | Onkyo Tx-sr507 A/V Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Tv screen turns green after about 20 seconds on cab/satellite mod
called onkyo about this - plug into HDMI input 1 (DVD) instead of HDMI input 3.
Apr 09, 2009 | Onkyo TX-SR606 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Blank display on a Onkyo TX-SR501
if these don't work possible that the light of the display has blown.
good luck
smeags.
Dec 31, 2007 | Onkyo TX-SR501 Receiver
Onkyo HTR500 Receiver Logo
57 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
