Question about Canon Cameras
I have a canon powershot SD400 elph. Camera menu
I have a canon powershot SD400 elph. Camera menu will not allow me to format a new SD card. Choice is presented but is not lit up to choose.
  • Canon Master
  • 4,738 Answers
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Posted on Dec 12, 2009
I bought a new memory card for my Canon Power Shot SD 400 Digital Elph, but it has an error message that comes up. When I scrolled through the Menu to format the card, the format selection is grey and...
Your older camera can only work with 2GB or smaller standard SD cards. It is not capable of recognizing the newer format 4GB or higher SDHC cards. Fortunately, old format 2GB SD cards are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them.
Sep 02, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Can not format new card, not sure why this is happening?
Have you used the correct card?
It's very common for users to try too large a capacity or even the later SDHC cards which were designed long after your PowerShot SD400 / Digital Ixus 50. That camera can only accept SD cards to a maximum 2GB capacity, and with some brands it's a bit fussy and will only accept 1GB.
Also note that your camera does not need high speed SD cards, if you put an advanced speedy model in there it will work (subject to the previous restrictions) but your camera lacks the ability to make use of the speed.
Aug 02, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD400 No memory card message, but there is a memory card installed. Tried multiple memory cards and got the same message. Made sure the memory card was locked.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. By the way, if you're using 4GB or larger SDHC cards, they won't work with the SD400 as that camera was made before SDHC came out. Consider 2GB or less standard SD cards only. They're very inexpensive these days on Amazon..
Dec 27, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
I have a Canon SD400 Powershot digital camera. It
First, make sure your camera can accept SDHC cards. If the camera says the card is locked, move the slide switch on the side of the card.
Jun 13, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
My canon powershot SD500 elph's card is locked..one solution someone suggested was to slide the little slider on the side of the card. This card doesn't have that. I put these pictures to my computer but...
Maybe you could try to format the card in the camera. If that doesn't work, try formatting it in the computer. (The card alone, not the camera connected to the computer) Otherwise I think it's broken. Do you use a micro/mini SD adapter? If the contact is bad, it may tell you "Memory card error" and "card locked" at the same time. Check the contact.
May 21, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
My Canon SD400 will not recognize the memory card when inserted now. it says "no memory card found". is there a fix for this ?
Is it a new 4GB memory card? If so that might be your problem. The card would likely be an SDHC card, and your camera was designed well before the SDHC format came out. Your camera can only use standard SD cards (2GB or less). But if the card is 2GB or less, see this link for additional things that you can try.
Feb 21, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
160 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
