Question about Toshiba Satellite M35X-S111 Notebook
After fixing power jack problem secreen will not lit
Toshiba satellite M35X-S111
After solving the jack problem.
when I click on the start button I hear the fan voise but there is nothing on the moniter and no sound.
When I remove the connection between the start button and the mother board and put it again it works two times and then the problem started again.
The computer may work random at sometimes.
Is the problem in the small board and the cable which between the start button and the mother board ?
If yes how to purchase it
Posted on Feb 08, 2010
AC Power Adaptor LED won't stay on to power PC
First you you should test the AC power adaptor properly, then if it is in good conditions is important to test the electric circuit in the motherboard in order to find any trouble. There is a SMD fuse between de DC power jack and the rest of the circuit.
Jan 06, 2014 | Computers & Internet
Will not power on
When you connect the power, does the charge light lit up? this would tell you the power is transmitted to the battery, wich would mean your DC-jack (where the power goes in) is fine, and the problem might be fixed by:
  1. removing the battery,
  2. remove the power,
  3. hold powerbutton for 20 secs,
  4. re-insert power jack(not battery)
  5. press power on button.
If that didnt work, try the following to determine the DC-jack is the problem:
  1. remove battery
  2. insert power into dc-jack
  3. gently press the power plug into various directions while constantly pressing and releasing the power button.
  4. at some point the laptop should respond by turning on, meaning that you have a faulty dc-jack, which needs re-soldering or even relacement by soldering to repair.
Maybe you also notice that the power connector is very loose in the dc-jack, this might tell you that the dc-jack is the problem..
hope it helps..
Oct 15, 2013 | Gateway MX6956 Notebook
Charge loght off no power
Dell is famous for their power jacks coming loose...needs to be replaced to fix it properly, provided the blue ring is lit up on the power supply plug.
Oct 07, 2013 | Dell 14Z-N411Z
I don't see any data on my screen , but the secreen is on
YOU MIGHT WANT TO TAKE A LOOK AT THESE VIDEOS. GOOD LUCK.
Mar 05, 2011 | Acer V193w LCD Monitor
I have Acer laptop _TravelMate 5330_ the problem is there is no light on the secreen but there is a picture (I see my desktop on the secreen but in the dark, there is no light) so, I know the problem...
Do you really want to repair $5~10 assembly, unless you have tools for doing surface mounted component, you will be better off replacing it if you know for sure that it is not lamp problem. You have surface mounted fuse, MOSFET, transformer (you need ringer test for the transformer testing to find out if it has shorted turn), from all the repair I have been doing, I only fix it if it has bad solder joints on the transformer. You need a test lamp for testing inverter.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 24, 2010 | Acer Computers & Internet
The protection light is lit as stays lit and i have no sound coming out
if the protection light is on its an hardware failure
the protection unit will not let you power on the Amp
need to take to service
if you want to fix the amp let me know
ecrdn@yahoo.com
Jack
Oct 18, 2010 | TOA Electronics P-924MK2 Amplifier
HP pavillon dv6000 boot troubleshooting !
First take out the battery, and run it on AC power alone , if it runs ok its the battery that has died, it you still can run the laptop with orw/o a bttery then the internal power supply has died.
Jul 12, 2009 | HP Pavilion dv6000z PC Notebook
My Tomtom is not working
Unfortunalty , you have missing , corrupted or damaged files on your SD card. if you backed up your SD card earlier to a PC , then format and reinstall them to your TomTom SD card.
good luck
Nov 06, 2008 | Tomtom GO 300 GPS Receiver
IBM THINKPAD T30 BOOTUP PROBLEM
Hello I ahve worked on several of these. The problem is the Jack on the motherboard. You need to get a motherboard that is brand new. The jack from pluging in and out all the time makes a hairline crack near the jack.
Feb 10, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
