Question about Brother GX-6750 Typewriter
How do I replace the daisy wheel on my Brother GX6750 ?
    Champion:
  • Brother Expert
  • 270 Answers
There's a small handle a little towards the right of the print head. Pull it towards you to free the Daisy wheel, lift the daisy wheel up and drop in a new one. Always power off before you do this or you have to reset .
Posted on Dec 12, 2009
4 Suggested Answers
  • 14 Answers
SOURCE: Please send instructions to install a replacement
All you have to do is lift up the lid over the top of the printer. Make sure the machine is turned off. Remove the ribbon cassette. There will be a lever either on the left or right on top of the printer. Gently pull this toward you and the assembly holding the daisy wheel will drop toward you. The daisy wheel is is a transparent plastic case. Hold the tab and lift up the wheel. To insert the replacement is the reverse of what you have just done
Posted on Oct 14, 2009
faxman789
  • 297 Answers
SOURCE: reset code for daisy wheel
check this link on which printwheels work with your model to make sure you have the right one. There is no reset, except after you insert the printwheel and close the cover, it will automatically go to the proper position, unless there is something wrong with it.
See the instructions on page 12 of this manual:
http://www.brother.ca/en/products/pdf/manuals/GX6750-UG.pdf
Posted on Jan 18, 2009
  • 3594 Answers
SOURCE: i have a brothers gx6750
If you are not in KBII or a language mode the printwheel homing pawl is probably broken. You need a tech.
DickyO
Posted on Feb 16, 2011
My daisy wheel is not set correctly. How do I reset the letters to where they are supposed to be?
It sounds as if the wheel could be broken in the area that seats it correctly (sometimes a square or round hole in the ring of the wheel), or there may also be a dirty or bad sensor that detects the wheel position. Try a different wheel first then you might take some canned air to try to clean the sensor if you can locate it. If that doesn't work, you should probably let a qualified technician look at it to determine just what is going on. Hope this helps.
Feb 18, 2015 | Brother GX6750 Typewriter
The key I push is not the letter that prints
Many factors affect correct character selection. To isolate the problem, follow the directions below:
  1. Is the daisy wheel locked into the carriage correctly?
    1. Open the top, locate the black lever near the hammer and move it away from the platen.
  1. Lift out the daisy wheel. Inspect the petals to see if they may be damaged.
  1. Locate the small spring loaded pin near the center of the daisy wheel hub. If the pin is missing or sticking, or the daisy wheel has damaged petals, replace the daisy wheel.
    1. Look into the opening from where you removed the daisy wheel. Ensure that there is no debris in the area; use canned air to blow out the area.
  1. Reinstall the daisy wheel or install a new one if the old one is damaged.
  1. Remember to push the black lever towards the platen until it snaps into place.
  1. Close the top cover and turn on the typewriter.
    1. After the carriage moves to the left margin, insert paper, and open the top cover.
    2. Push the hammer forward until it presses the daisy wheel petal onto the paper.
    3. It will leave an impression on the paper; it should be a lower case "h".
    4. If the impression is any other letter than those above, the typewriter may require service.
  2. Examine the keyboard area. If there is any contamination, i.e. spills, pet hair, etc, the keyboard may need to be cleaned by a trained technician.
  3. If the problem is not resolved after these actions, the typewriter may require service.
Brother typewriters have a 90 day labor, 1 year parts limited warranty. For 90 days from the date of purchase, Brother International, or its Authorized Service Centers, will repair this product free of charge if defective in material or workmanship. After 90 days, and until one year from date of purchase, Brother will furnish, free of charge, a replacement part for the defective part of this product, you pay for labor.
If your machine is within Warranty, you can contact Brother Customer Support Center at (1-877-276-8437)
Apr 05, 2013 | Brother GX-6750 Electronic Typewriter
How do i set a new daisy wheel for the ML 100
1. Open the top cover.
2. Pull the lever towards you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press [CODE]+[RESET] to move the carrier to the previous position.
(make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right.
improper insertion of the daisy wheel may cause malfunction and incorrect printing.
It is not necessary to remove the cassette ribbon when replacing the daisy wheel.
Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
Dec 22, 2010 | Brother ML-100 Typewriter
Please send instructions to install a replacement daisy wheel on a brother GX6750 typewriter
Oct 13, 2009 | Brother GX-6750 Typewriter
Changed Daisy Wheel and it's still not typing the correct letters
You can see the info on replaceing the daisy wheel here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_GX6750_EN_214.PDF
If yo need more assistance- you can give us a call or send an email.
Take care and good luck
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082
Sep 15, 2009 | Brother GX-6750 Typewriter
Reset code for daisy wheel
Jan 18, 2009 | Brother GX-6750 Typewriter
GX6750 Typing wrong letters
Linda,first of all,does the daisy wheel spin when the typewriter is first turned on? if it does,then you will feel assured that it is installed properly. Next, refer to your manual to key board settings. It will indicate that there are settings for normal standard English keyboard and somehow that setting may have been changed. It would be also be important to check the daisy wheel to see if it is compatible with standard English keyboard...Cheers, John
Oct 21, 2007 | Brother GX-6750 Typewriter
Motor lock lever
The lock lever (black)is located on the right side of the ribbon holder.
May 12, 2007 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
570 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
