Question about Amana DLE330RAW Electric Dryer
How does belt wrap around tension pulley - Amana DLE330RAW Electric Dryer
  • 744 Answers
See the picture:
Posted on Dec 12, 2009
How do i remove the drive belt on a 2006 Toyota Solara?
Serpentine belt replacement is not complicated and requires only one tool. Find the tension pulley located at the bottom of the motor. This pulley is attached to a very strong spring and holds the belt tight against the pulleys through its serpentine route around the engine. Use a socket wrench with a matching socket the same size as the hex head bolt in the center of the tension pulley. Attach the socket and set the direction to tighten the same direction the spring action allows the pulley to move. Turn the wrench handle, the pulley moves and the tension on the belt slackens. Take the belt off the pulley and let it hang.
To install the new belt Once the belt is around the pulleys allow it to hang freely at the bottom of the engine. Again, use the socket wrench to turn the tension pulley far enough so the belt can be wrapped around the pulley. Once the belt is around the tension pulley, release the socket wrench and allow the tension pulley to take up the slack.
Good Luck!!
Nov 22, 2013 | Cars & Trucks
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Need serp. belt diagram for a 2000 ford escort zx2 dohc
If your diagram is missing from under the hood, I can give you a few tips that may help get your belt installed. (1) The belt will wrap almost completely around each pulley, no pulley will be wrapped less than 2/3 of the way around. (2) The ribbed side of the belt rides in the grooves of the pulleys, and (3) The flat side or back side of the belt wraps around the smooth pulley or pulleys. Usually at least the belt tensioner pulley is smooth and runs on the backside of the belt. You may want to start at the crankshaft pulley by determining which pulley on either side of the belt will provide the most wrap around the crankshaft pulley.Hope this gets you on the road.
Jun 16, 2011 | Ford Escort Cars & Trucks
I have a 92 chevy geo prizm but i can't find a diagram to change the serpentine belt
If you've lost the sticker under the hood and there is no diagram in the owner's manual, you can find it in a Haynes or Chilton's manual for your vehicle. It may even be printed on the wrapper for your new belt. Most auto parts stores also have a copy of the diagram.
If you're stuck out in the boonies, the old belt is already off, and don't have any of this information, you'll have to work it out. Start by noting the grooved side of the belt is on the inside. The crankshaft pulley on the bottom is generally grooved. Look for the next pulley in line to the upper left from the crank pulley. It is probably smooth, so the belt goes around it counter-clockwise from right to left (smooth side). Next should be a grooved pulley, so the belt would wrap around the outside in the clockwise direction. Continue working your way around in this manner until you get back to the crankshaft pulley. The rule is "clockwise is groovy." Make sure you pick up all of the pulleys. As a check on your work, verify that the belt tensioner would pull the belt tighter when installed according to your diagram. You most likely have two or even three grooved pulleys in a row at or near the top - this will be a straight shot with no wrap around a smooth pulley.
The belt tensioner is generally a smooth pulley and is often the first one off the crankshaft pulley going clockwise. The A/C clutch, power steering and alternator are generally grooved. The water pump may be either one and is often the last one going back to the crankshaft pulley. It is rare to have two smooth pulleys in a row. The belt is never arranged so it contacts itself on a full wrap. If the belt is very loose when it's engaged on the tensioner, and the tensioner spring isn't broken, you'll have to rework your tentative diagram - the belt may go across the pulleys in a different order.
The most difficult part aside from working out the proper belt wrapping is loosening the belt tensioner so you can get the belt on. Some vehicles require a breaker bar and socket on the tensioner center bolt (there's no room for a ratchet). Others have a slot in the side of the tensioner where you can insert a large screwdriver to pull against the tensioner.
Jun 06, 2011 | Chevrolet Chevy Cars & Trucks
Belt removal
Locate the tensioner pulley usually near the alternator . Draw a diagram of how the belt wraps around the pulleys. Place a box end wrench on the bolt in the center of the tensioner pulley and pull on the wrench to rotate the tensioner and relieve tension on the belt. If the tensioner is stiff , place a tube over the wrench to increase leverage. Slide the belt off of the tensioner pulley and remove.
Jan 06, 2011 | 1999 Plymouth Voyager
How do you replace serpentine belt?
This is a simple technical task,just ensure you follow the instructions below carefully;
STEP 1 Open the hood and locate the accessory belt diagram, which shows the routing of the belt in the engine.
STEP 2. Turn the tensioner pulley to the right by placing a 15-mm wrench on the bolt in the middle of the tensioner and rotating the entire pulley. The tensioner pulley is located in the middle of the power steering pump and the crankshaft, and across from the water pump.
STEP 3 Pull the belt off one of the pulleys and slowly rotate the tensioner back into its original position.
NOTE;The tensioner pulley is spring loaded. If it snaps back into place, you stand the risk damaging the pulley.
STEP 4 Remove the old belt from the other pulleys and discard it.
STEP 5 Carefully Wrap the replacement serpentine belt around all but one of the pulleys using the belt diagram as a guide. Choose a pulley that is easy to access, i will suggest the power steering or tensioner pulley.
STEP 6 Hold the belt tight and rotate the tensioner pulley to the right.
STEP 7 Gently Slide the belt around the open pulley and move the tensioner pulley back into position.
FINAL STEP Ensure that the belt is properly wrapped around all of the pulleys. The belt sits in the middle of the groove of the pulley when properly installed.
Problem solved,good luck....
Aug 16, 2010 | 1996 Chevrolet Cavalier
How to wrap belt around belt and drum tensioner
These are a pain to do. You have to put the belt around the drum and at the motor, there is a pulley on a spring device.Twist the pulley toward the motor, until you can get the belt onto the motor pulley. Release the spring loaded pulley and it will automatically tighten the belt.
Oct 05, 2009 | Whirlpool Dryers
Need diagram showing how to install belt belt came off need to know how it go on and how to ajust it
first jack up the right front tire side of your car and remove cover under your car motor, so you can see your pulleys from underneath your car, remove black cover where your timing chain belt is thats on the top center between alternator and powersteering pulleys, ok,looking at all your pulleys from your right side of your front end, starting from your top left is your alternator pulley,put belt on it and go underneath the motor mount to your right top powersteering pulley,then go down around the bottom right ac pulley,then to your left bottom crankshaft pulley,the back side of the belt thats on your top alternator pulley wraps around the soft edge pulley thats above your center waterpump pulley,then wrap around the idler pulley that's under your top alternator pulley,then wrap the backside of your remaining belt around the tensioner pulley that's in on your right, under your top ac pulley, use a 13 mm wrench to adjust by turning towards the back of your car so you can slide the belt on
alt ps
soft edge
idler wp tensioner
cs ac
Jul 12, 2009 | 1999 Ford Escort
Need the belt diagram for the water pump belt for a 95 Auroa
42161874BELT, REPLACE
  1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
  2. Raise and support vehicle.
  3. Turn wheel to the extreme right and remove right side splash shield.
  4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
  5. Lower vehicle.
  6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
  7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
  8. Remove belt from power steering pulley and set aside.
  9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
  10. Install right side splash shield and lower vehicle.
  11. Position belt around power steering pulley and release tensioner.
Nov 23, 2008 | 1995 Oldsmobile Aurora
Change a belt?
Replacing the belt is not that hard.
  1. You have to take the back of the dryer off.
  2. Then lift the tension arm on the motor releasing the pressure on the belt.
  3. Inspect the tension pulley, checking the bearings on the pulley.
  4. Wrap the new belt around the drum, and wrap it around the tension pulley, lifting the tension pulley to adjust the belt.
  5. Reinstall the back of the dryer.
Please rate this solution
Aug 03, 2008 | Whirlpool LEQ9858P Electric Dryer
Amana DLE330RAW Electric Dryer Logo
219 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
