Question about Mastercraft Garden
Gas does not flow out after I loosen the gas valve from snow blower
  • 98 Answers
Vaccume lock in the tank
Posted on Feb 20, 2010
Where is gas shutoff valve for 31as6bce799 Model number craftsman snow blower
if it has one it is on the bottom of the gas tank .
Nov 28, 2016 | Garden
Where is the gas shut off valve on craftsman snow blower
Where is the gas shut off valve on craftsman snow blower Google Search ..try looking here it does show a couple of pictures but not sure if the one you are after is there.
Nov 27, 2016 | Garden
Why does it run for 10 mins, then stops?
Loosen Gas cap and see if that helps. Many times the Gas tank Vent gets clogged. When engine runs, it creates a suction and starves the engine of gas.
OR
If the engine was stored with gas in it, sometimes the Rubber seat in the carburetor deforms and wont let the gas flow into the Carb Bowl at a fast enough rate to keep up with the running engine. The bowl empties (after 9 minutes) and the engine quits. Takes a while for the bowl to refill (5 minutes).
Jan 16, 2016 | Toro Snow Blowers. Power Clear 621 QZR 21...
Why won't it keep running?
some times gas tank vent gets clogged . Loosen gas cap and see if it stays running to verify clogged vent.
Ethanol gas can ruin the Seat or Needle valve in the carburetor. A result of that can be very slow flow of gas into the carb. So maybe you can run it for a while but then the Fuel bowl empties and engine dies. Wait a while and there is enough gas in Bowl to repeat running.
Jan 05, 2016 | Garden
Snowblower won't start
"Gone thru Carburetor" Did you check the Needle valve Seat? The ethanol gas ruins the seat if they are made of rubber and the needle valve is all metal.
Does the Float actually move up and down as it's supposed to? sometimes the ethanol gas absorbs too much moisture and the needle valve or pivot point of the float rusts.
Mar 01, 2015 | Toro Power Clear 418 ZR - Single Stage...
What causes snow blower to start then stall?
sounds lie the Carburetor needle valve is restricted so you are basically running out of gas. By the time you move around to start it again, a little gas filled the Carb Bowl again. Take the Bowl off the carb and if the Needle valve is all metal, check up where the needle valve goes to see if the Seat up there is cracked from being dried out by ethanol fuel. If the Seat is the rubber ind, it can be replaced for cheap.
Feb 16, 2015 | Garden
Just installed a new carburetor on a Tecumseh Snow King 8 hp engine. Gas is getting to the carburetor but no gas is filling the bowl and engine won't start
Sounds like the carb needle valve is stuck closed. Try loosening the bolts holding the carb to the engine, then tapping the carb lightly with a hammer. If gas then flows to the carb, re-tighten the carb bolts evenly and not too tightly.
Dec 27, 2014 | Tecumseh Garden
S 140 snow blower
It sounds like the float is stuck, or at least the needle valve controlled by the float is stuck open, therefore not stopping the flow of gas into the carbureator. Time to rebuild the carb.
Apr 26, 2014 | Toro Garden
Ran perfect last yr , gas was stale drained carb bowl and replaced gas it started up right away then cuople mins later it started blowing oil out of the oil over flow tube
Sounds like the Needle valve in the carburetor is stuck 'down' letting gas continually run from gas tank into carb. When the valve can't go up (Close) gas will run past the carburetor and into the crank case I bet your oil is full of gas. Check oil level see if it is overfull
Jan 22, 2014 | Tecumseh Snowblower Snow Blower Starter...
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
Garden Logo
147 people viewed this question
Top Mastercraft Garden Experts
john h
DROPNDEAL
DROPNDEAL
ray gallant
Are you a Mastercraft Garden Expert? Answer questions, earn points and help others
