Question about Royal 10X Shredder
Plastic separator missing
There is a plastic piece between one set of the cutters that is broken and missing. Is it possible to buy just the part and repair it ourselves or is it worth fixing?
It is a tedicous process but it can be done. Disassemble the unit (remove the gear cover). remove the cutters and use an end plastic and place it where it is most needed, usually somewhere in the center of the cutters. Make sure the cutters are oriented in the same direction so as not to jam the paper. Reassemble in reverse order. Make a diagram of the preassembly and use it to reassemble the unit. Take your time. Perhaps you could request a replacement plastic. I just used a plastic washer on the ends. I do remove shredded paper once in a while but that is just preventive maintainance. Hope this helps.
Posted on Mar 10, 2010
I disassembled the Stanley 10 - 788 utility knife completely how do I put it back together
This utility knife reassemblies similar to the original. The only difference is this model uses two screws and that plastic insert. You will align the two metal halves and bring them together. Use care that the blade does not fall out of its holder and the little black plastic piece stays in place, near the blade. This may take a few tries. after you bring the two halves together you will carefully separate the bottom end (farthest from blade). Separate it just enough to slide the plastic insert into position. Once the three pieces align you will know. With little effort the two metal halves will close together. Install the two set screws and test for proper function. I'm including a Youtube video that shows how to properly change the blade and what it will look like after it is reassembled.
https://www.youtube.com/watch?v=5napTSRSyeQ
Sep 23, 2018 | Cutter Tools
I don't know much too add to describe my
can you contact customer service at braun and ask them if they supply replacement parts and how would you go about buying one? hope this helps.
Oct 31, 2017 | Health & Beauty
Is it possible to buy plastic cheap pizza cutters that you can give out with pizzas? We are doing a pizza fundraiser and I thought it would be cute.
Yes!! Check out this website that sells bulk amounts of cheap plastic pizza cutters that you can give out and maybe even print something on them.
Good luck with your fundraiser.
http://www.jhstudios.com/?promotional_giveaways=plastic_pizza_cutters
Feb 28, 2013 | Home
Alternative replacement knob for lg #LRG30357ST, originals are plastic and all broken
Last time I bought replacement knobs (LG) from amazon. Take a look here Amazon com LRG30357ST knob. I hope this was helpful. cheers
Feb 05, 2011 | LG LRG30855ST Stainless Steel Gas Range
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Jan 14, 2010 | Braun 360° Complete 8985 Electric Shaver
Plastic teeth are broken
You could possibly replace these but it would be more cost effective to just get a new one.
Nov 03, 2009 | Fellowes DM8C Cross-Cut Shredder
I was cleaning my bobbin case and the cutter and blade came off. Can you send me a picture so I can put it back together?
I don't think I have a picture but let me see if I can describe it to you.
The metal cutter has a black plastic piece. The blade fits in the black plastic with the longest point on top. The black plastic piece slides back onto the metal cutter, riding on the ridge. Fit the metal cutter back on the unit, being sure to align the "stubs" in the holes of the black pieces attached to the cog wheel. Make sure the "stub" of the black plastic piece with the blade fits in the parallel groove so that only the metal piece moves out and brings the thread to the blade when the cutter is activiated.
If you are still unable to fix, make a comment back and I'll go take pictures of my machine's cutter system.
Good luck.
Sep 03, 2009 | Husqvarna Viking 1
96 dodge grand caravan drivers side power window---i have broken the nylon slides that attach to the window itself= do i have to replace the whole window monitor or can i buy the two nylon plastic slides...
It sounds like the Regulator is broken and needs to be replaced. Below is a picture of how the glass attaches to the regulator. Note the gold colored clip in the back that holds the glass to the regulator. IF the plastic piece that broke is the WHITE piece in the picture (yours may be black) then it is part of the regulator.
(the black piece in the picture is part of the glass)
480308c.jpg here is a diagram of your door glass / regulator.
b6fdf08.jpg Hope this helps
Apr 16, 2009 | Dodge Grand Caravan Cars & Trucks
GE Profile Spacemaker XL1800 Microwave Model # JVM1870SF001
(I also replied via e-mail)
Sorry, but the subject lines get cut off after so many characters.
Thanks for replying.
Part # DE63-00204A looks like a valid Samsung part number but it doesn't show up anywhere, so it's likely a proprietary part made only for GE and not available separately.
You can see a helpful exploded view of this model here.
Then you can go here and enter your model number and come up with the parts list. This site has much better prices than GE.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Chances are you will end up having to but more than you want to, but not the whole door.
Sep 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Royal 10X Shredder Logo
133 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
