Question about JVC TH-S3 System
Static sounds our speakers sound like static, but only when watching dvd"s, not when listening to cd"s
  • 84 Answers
Try to check the av output wire at the back if its properly connected
Posted on Jul 21, 2008
Hello my name is Leo, my cd/dvd player sounds skippy when i play a cd But when i copy one to itunes and down load to my Ipod it sounds good. it also sounds good if i play a song from a playlist What...
the disc might have a few scratches or your cd/dvd player might not be getting enough consistent power make the leads are securely connected and are not faulty also you might have a dust build up in your computer
you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Mar 19, 2011 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Sound problems
panasonic sa th-440 f61
Aug 18, 2009 | Venturer STS152 System
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
Static from speaker
Try playing around on the volume control panel. The pan might have been played with, along with other things.
Feb 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Dvd player
If you have a factory DVD player, then while the DVD player is on, press your radio preset numbers' 2 and 4 simultaneously. Then to listen to the CD or radio just press whichever button you want to listen to. You should hear sound out of your front speakers only, and won't interrupt the headphones. Good luck.
Nov 02, 2008 | 2005 Ford Freestyle
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
DVD player
well on mine, I have to turn off the sat. radio before the kids can watch dvd and I can only listen to radio or cd while they watching dvd. I don't even know if you are able to listen to dvd through them speakers, because it came with headsets. I know I am not big help, but I think you have to change something on the front radio. If nobody else can answer your question, than I will look tomorrow to see how I turn on my dvd player and tell you what I have to push.
Sorry
Tanya
Jul 06, 2008 | 2004 Ford Expedition
This could be a couple of Things.
First if it,s DVD Player related. it could be that The DVD Player, needs the laser Head Cleaning. Any dust-grease or similar on the Laser head, will cause Distortion. The second option is the DVD Player itself. Some DVDs are removable Drives. with An eject Rom button underneath the Laptop. This will enable you to remove. Check the drives connection Pins At the rear of the Drive. ** Clean with a Bud/Swab moistened in lighter fluid/Meths** replace the Drive.
The other possible problem would be with your Laptops Sound Card/ Board if Fitted.
Finally The problem could be related to a motherboard Fault i.e Bad earth or other internal Component Fault.
Go simplist first ( clean the DVDs Laser Head.
Then Remove the actual DVD Drive if Possible. ** Check Connections At rear** Ensure that the drive has not been dislodged from its connector to laptop mainboard.
Regards And Good-Luck.
Mike @ compurepair.
Jun 26, 2008 | Dell Inspiron E1705, Intel Core 2 Duo...
Problem with Surround Sound when watching TV
No wonder you havent gotten no reply your listed under wrong tv
May 06, 2008 | RCA D52W19 52" Rear Projection Television
JVC TH-S3 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
