Question about HP Pavilion dv9005us Notebook
During reformatting my Notebook pc, computer shutdown as required and now will not turn on in anyway. there is no fan or any internal power from what i can see. when I press the power button nothing happens, and the only visible sign of anything happening is the blue light around where the power cord is plugged, before reformatting computer was working excellent, could you please let me know what this could be or please steer me in the right direction to try and fix this issue? i appreciate it
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
This problem gets broken or parts of it may be to damage.in fact for me is rarely knows this defect,but for the sake of others and to help all I can give tips.the death of your laptop is still broken because of the memory or may also loose.most damage is the laptop memory, the reason may be the excessive use or it may be old, the memory of lapatop was destroyed because of heat coming from inside the laptop can not get out, and then rest to use and The rest is memory does constipation from heat and cold then re-used.The simple explanation is that I help you a great, many thanks..
Posted on Dec 12, 2009
My Nextbook 11a keeps shutting itself down Message is THERMAL SHUTDOWN COULD YOU PLEASE HELP ME CORRECT THIS ISSUE IF POSSIBLE THANK YOU Cheryl Dodson
A thermal shutdown occurs when a computer case or central processing unit temperature reaches a critical level at which point the computer will automatically shut down to avoid permanent damage. There are a variety of factors that can cause your computer to overheat and a range of external and internal problem origins; in some situations, you may not be able to fix the problem and will need to simply adjust your use patterns. Fixing a thermal shutdown may take hours and may require the replacement of potentially expensive computer components.
Here are a few troubleshooting steps you can use to help you.
Step 1
Leave your computer off for a few minutes after a thermal shutdown. You may be tempted to turn it back on and see what the problem is, but this is dangerous for its internal components. They need 10 to 15 minutes to cool down, depending on room temperature. If the room is hot (80 degrees Fahrenheit or more), you should wait until the room has cooled down or move the computer to a cooler location. Do not put the computer in a refrigerated location; the sudden drop in temperature may warp and crack its internal parts.
Step 2
Detach the computer's power cable and open side door of its case. This may require a No. 2 Phillips screwdriver. With your small flashlight, visually inspect the inside of the case for physical damage -- things that look burned. Smell the inside of case for the odor of melted plastic. If you detect this, something has probably been damaged beyond repair and the computer needs to be sent to a technician. If this odor is present, close the case; plastic fumes are toxic.
Step 3
If there is a lot of dust in the case or around the vents, clean it out. Dust acts as an insulator and can contribute to overheating. Remove the dust using short bursts from a can of compressed air. Hold the can vertically, perpendicular to the floor, when spraying. If the can is angled, it may spray frozen gas.
Step 4
If the inside of the case appears undamaged and clean, reattach the power cable, but do not close the case door.
Step 5
Do a quick check for mechanical failure. Turn your computer on for about 10 seconds and observe its system fans, CPU fan and video card fan (if present). All of these fans should be spinning. Put your hand outside the case and behind the power supply unit. You should feel warm air coming out of the grill behind the PSU. If the PSU fan is not working, the PSU needs to be replaced or its fan needs to be replaced by a trained technician. If the other fans are not spinning, check their connectors for damage or looseness.
Jun 01, 2017 | Computers & Internet
Auto shutdown during work
it could be that the fan of your processor stops working or not working at its full efficiency, you should check underneath your laptop unit if the processor fan that blows away the heat generated by processor and chipset during heavy load of work.
Oct 21, 2013 | Lenovo Computers & Internet
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
I have an acer aspire ax5900. The video card fan vibrates loudly for the first 10 minutes after start up. I am told I need a new video card. Is this correct and where is the best place to get one?
Normal Operation
Troubleshooting
Solution
Computer don't shutdown normally, it only shutdown manually by shutting button only
There's a big confusion here...
What do you mean by manual shutdown??
Some of the replies refer to Pressing the power button and wait for the computer to shutdown... while some refers to Holding your power button until the power is off... which are two different things.
Referring to Manual Shutdown #1 (Pressing the button): It doesn't hurt your computer since it is just the same with going to 'Start>Turn Off'... its just a shortcut button!*
Referring to Manual Shutdown #1 (Press and holding the button): This will sometimes result in data corruption, why? Because during the normal shutdown process, Hardrive Read/Write heads are being parked on the SafeZone. Doing this will just leave the head on top of the plate destroying some precious data
Aug 12, 2010 | Acer Aspire One PC Notebook
Internal microphone not working
I have Dell Inspiron 1520 and I have issue to built in microphone is not working. I tried to execute the Sigma Tel driver from Dell Driver and Support website but prompted 'Exit Error; Error : Device Object not present, Restart system and run setup. Then, asked Dell support to help and they are not really helpful, after System Restore and drivers upload and finally asked to reformat the laptop........
Anyway, this is what works for me.
1) Download the Sigma Tel driver from Dell Support Drivers page and save it in Desktop
2) Shutdown your computer
3) Start your computer and press F8 at the Dell Logo page
4) Select Safe Mode (not others)
5) Proceed to work on Safe Mode
6) Right-click the Sound icon and activate the Sound icon
7) Select Recording device.
8) If still not working, then execute the Sigma Tel driver that saved in desktop
then, shutdown the computer and start as normal, you may see the system able to detect the built in Microphone then.
Hope it will work the same for you too..!!
Apr 20, 2010 | Dell Latitude E6400 Notebook
Fan shuts off on computer startup, led lights are
The fans are USUALLY controlled by the processor chip reading its internal temp and running fans as needed. Under the varying load during boot, it is not uncommon to have fans starting and stopping..
Nov 30, 2009 | HP Pavilion dv6000z Notebook
Notebook won't reboot because windows failed to load because the system registry file is missing or corrupt.
Hi...
This is a Operating System problem, did you face and error during you've reformat your computer. Some of the components of your Operating System are corrupted you need to re install the windows CD to fix the problem.
Mostly of the causes in this problem is not shutdown the computer properly,
Note: If you can not shutdown you computer properly it will cause file corrupted.
Regards
ICmanServer
Jul 31, 2009 | Computers & Internet
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
HP-520 shutdowns while restaring after vista updates installed
This is something you no longer have to worry about. Vista is no longer being supported so Microsoft will no longer be releasing new updates.
Windows Vista Reaches End of Life Capital Support
May 06, 2017 | E-Machines M5310 PC Notebook
HP Pavilion dv9005us Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
