Question about Refrigerators
I have an amana sisde by side and over the last few days i've noticed the freezer has had alot of water in it as though someone keeps leaving the door open. yesterday it was everywhere. now it seems as though the refer section is also getting warmer now, too.
    Problem Solver:
  • 11 Answers
You might be low on gas in your compressor or coils froze pull the panal off the back and if its frozen take a hair dryer and thaw it out also take a vacuume and cleand oll the dust off coils that might help too if its a gas issue you cant fx that bye yourself
Posted on Dec 12, 2009
Testimonial: "thanx "
Water dispensor not working
Assuming this is a GE side-to-side - I had this problem for the last few years -yes turning off the freezer with the door open for a few hours worked but is a royal pain in the neck. Using a hairdryer for 15 minutes does too, when it keeps freezing up agin every day. I also had a repairman install the GE kit to keep it from freezing - it worked for awhile, but then stopped working, and the water line again froze up. Looking at solutions around the Internet, the one that made the most sense suggested that there was insufficient insulation in the freezer door directly behind the water dispenser; i also noticed freezing air blowing directly there when the freezer was running. So I simply stuffed a cloth towel on the inside of the door where the ice comes through, and hanging down in front of the flat part behind the dispenser - and it did not freeze for several days. i then got a flat piece of insulating styrofoam, about 10inx11in, attached it by velcro to that flat part on the inside of the door, and have not had a problem since.
Feb 22, 2011 | Refrigerators
Describe your frigidaire frs23f5a freezer
With ours it is ice collection on the fan in the freezer section. This is located about half way down under the icemaker (please unplug to proceed). If you remove the four hex head screws and lift up the metal flap you will find the fan assemble and most likely the ice build up to chip off.
Jul 01, 2010 | Frigidaire FRS23KF7AB Side by Side...
Not cooling
If it's clicking on and off like you say, replace the compressor start relay device and overload protector. These are located directly on the side of the compressor, usually contained within a dark plastic cover.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
M y refrigerator has turned into one big freezer!
You need to reset the controls to the middle range and alow days for adjustment. If 1-9 set at 5. this wqill take a while to rush leave the door to fridge side open for one hour.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side with ice/water in the door freezer stops freezing about 8 yrs old
First of all the worst thing you can do is set your fridge on the highest setting even though it has it. That's live reving your car to the red line just because it has it. As far as your challenge is concerned, it sounds like a breach in the seal of the fridge or dispenser. Check to see if the ice despenser is closing properly after use and check the door seal to make sure it's closing tight when the door is closed. To do this, simply inspect it for any bad wrinkles, cracks, folds, etc. if none are visible close the door on a dollar bill and make sure it holds securly all the way around the door. I f it doesn't, the seal may need to be replaced and/or the door is warped. If you continue to have issues, post again, we will work this out.
Jan 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
Jul 18, 2008 | KitchenAid KSCS25FKSS Side by Side...
Bottom freezer
It may be that the door was completely closed at some time this will cause this fault, or you have a defrost sensor fault. Regards Advisor
Aug 20, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
