Question about Whirlpool LSN1000LW Top Load Washer
Washing machine smells like burning rubber!
My washing machine smells like burning rubber and will not start. It only makes a clicking sound after filling with water. The load is not too large and the agitator spins freely. Help!
  • 5 more comments
  • Anonymous Mar 13, 2014
    whys my washing machine shutting down and smells like burning rubber its only a year old
  • Anonymous Mar 15, 2014
    washing smells of burning rubber
  • Anonymous Mar 19, 2014
    has a smell like burning rubber
    drum will not spin, agitator does not work and have smell of burning rubber
  • Anonymous Mar 21, 2014
    it makes out a click sound as it is starting but it not
  • Anonymous Mar 23, 2014
    My washing machine timer had a burning smell. I removed it and it is burned internally. I just want to know if I should check anything else before replacing the timer. I don't want the new timer to burn out.
  • Anonymous Mar 25, 2014
    Full of water and makes a buzzing sound.
    President:
  • 1,314 Answers
Sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 20, 2008
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Burning smell when I turn on machine to start washing
Your heater is coming on with no water in machine hence smell sounds like pressure swith is jammed on depending on make could be blockage in pipe making switch think water in machine swith on heater...Remember electricity can Kill...proceed wit h caution....Find hose and give it a clean check also chamber
Sep 28, 2009 | Washing Machines
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
WASHER STARTS MAKING LOUD NOISES WHEN SPINNING SOUNDS LIKE IT IS OFF BALANCE BUT NOT. ALSO FAINT SMELL OF BURNT RUBBER.
The washing machine will do this if the load is unbalanced. Usually due to either an excessively heavy and/or large load. The burning rubber smell is just the drive belt dealing with the imbalance. Often the washing machine will self-balance itself, but it's a good idea to open the lid and re-distribute the load. Or remove some stuff if it seems too heavy.
Sep 06, 2008 | Maytag Washing Machines
MAV Atlantis 6000
hi. thanks for the question .the clicking sound is something caught, in water pump. the rubber smell is the belt . pull washer away from the wall. small door at the back left corner ,remove pump on the floor. remove 3 3/8 bolts remove. replace . belt underneath washer . replace thanks the appliance doc please rate me
Aug 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine started making noise in spin cycle and then there were fumes
The belt is loose and slipping. They were probably, black and smell like burning tires!
Just in case it was a wire burning!!
Call service this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Whirlpool LSN1000LW Top Load Washer Logo
2,907 people viewed this question
Dan Webster
Dan Webster
Sal De
