Question about Nokia 6100
Nokia 6100 will not start up after software went haywire when saving an edited text message. It lights up for a moment then goes blank, no screen illumination. MC
I have had my nokia n96 for just over a year now, and had no problems, but all of a sudden, my mobile went haywire when sending a text message when the battery went flat. When recharged it wont let me...
Possible that the phone has hung up because there are errors in the software.We can try a reset as last resort before deciding on the phone software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
May 03, 2011 | Nokia N96 Smartphone
When I got a text a message came up saying I was running out of memory. I went and cliked to deleate my inbox and it started clearing the old messages but then it froze. I tried pulling out the battery and...
try to reset:
press "*" (star) and "3" and "on" switch together and wait until unit turns on - it will ask for format confirmation. remember to save all contacts (numbers etc) before doing format otherwise you loose them all...
regards
Feb 20, 2011 | Nokia 5130 Cellular Phone
N96 keeps crashing, shortcuts missing, messaging already in use
Its been a year so there must be definatel a newer firmware version available for your phone. Just get the Nokia Update Manager software in your computer and try updating the phone. Should solve all your problems and just make sure that you take a back up of your data because after an update you will loose all your phone memmory data. Mass Memory stays unaffected.
Sep 18, 2009 | Nokia N96 Smartphone
Can't multimedia message from sci phone how do i set up for at&t
must be peformed exactly.
MMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
Apr 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Unable to text
This is a common problem. But there is a solution for this problem.
go to Messaging. Then hit Options. Scroll down to settings.
Hit text message. Options - Then "Message Centres".
Hit the Edit button and the following number should come up:
+47973100973
Save it and try sending messages. If again the same problem exist then call up your customer care who provides the services of your phone like Airtel, Reliance etc.. Ask the message center number and follow the above steps and save that service center number. Hopefully it should work. Thank you......
Sep 12, 2008 | Nokia N73 Cellular Phone
Blank screen with cursor
MS-DOS edit command help This would bring up a blank edit screen, as long as the file is saved upon exit
Click on the above link , Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell Inspiron 1000 Notebook
Nokia7370- retrieval of data
Hi there, the only way that u can get a back up of your messages and contacts is by using a nokia data cable here is a link to a google search
and here is a link to ones on ebay
once you have the cable you can use it connect to the phone to the PC, software can be downloaded form the nokia site.
Alternatively if the messages are saved on sim card they can be viewed on any other mobile phone.
Hope it helps
Z33m
Dec 10, 2007 | Lands Phones
No text message
try master reset or master clear
Sep 21, 2007 | Motorola Mobility RAZR V3
Nokia 2270
1,Replace the display
Aug 27, 2006 | Nokia 2270
Nokia 6100 Logo
114 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
