Where do plugs go on back of unit. have direct tv receiver
Where do plugs go on back of unit. have direct tv receiver.
  • 1 more comment
  • petehour Dec 12, 2009
    what about the other 6 cables with a plug at each end?
    btw, the cords are color coded- 2 whitw, 2 red and 2 yellow. all 6 are plugged into the tv. others got unplugged somehow.
    there are 11 places to plug in jacks on dvd and 6 on dish receiver. tv's are okay. soon as i figure them out, i'll accept. sorry to be such a problem
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow the following steps to connect DVD with Direct TV Receiver---
Place the VCR and DirecTV box near each other. This depends on your entertainment setup. However, you can place the VCR on top of the DirecTV box or next to the device. Be aware of any vents on the top or bottom of your VCR and DirecTV box. Do not block the vents.
Hook the first coax cable to your "Antenna In" outlet on the back of the TV. This is your metal cable TV connector. Turn the coax until it is securely tight on the back of the TV.
Screw the other end of that coax cable into your VCR. Find the metal connection that is the "RF Out" or "Antenna Out." Tighten the end into the VCR until it will not turn anymore.
Use your second coax cable and fasten it to the "RF In" or "Antenna In" on the back of the VCR.
Screw the other end of the second coax cable into the "Out to TV" on the back of the DirecTV box. Be sure that all of the coax cables are tightly secured to the devices.
Plug your VCR into a surge protector. Then turn on the VCR.
Add your VCR to your universal remote. Instructions for this process are located in the remote manual. Change between your DirecTV and VCR by pressing the "Input" or "TV/Video" button on your remote.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 12, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Dec 12, 2009
    If you have coaxial cable hook it
    from satellite to the satellite in jack on the satellite receiver and the out
    to TV coaxial from the satellite receiver to DVD/VCR plugged to antenna in on
    the VCR and a coaxial cable from the DVD/VCR to the TV coaxial antenna in on
    the TV. Now you can watch satellite without turning the DVD/VCR on by switching
    off the satellite receiver. Now run the video cords red, white and yellow out
    of the DVD/VCR to the TV.
    Thanks
    Rylee
  • Rylee Smith
    Please reconnect the unplugged cords into the DVD in the
    same sequence and AV input and output.
    Thanks
    Rylee
  • Rylee Smith
    No need to be sorry. This is rather my
    pleasure to provide assistance here. Please take your own time and accept the
    solution only when the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Video in not working
When you plug the AV cables into the receiver make sure that the channel that it is plugged into is selected on the front of the receiver. Also note that the receiver should have a monitor output that should be plugged into the TV and the TV input must be selected on the TV.
Jan 31, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
Smart TV but reveiver does not have HD plug ins
I would input everything directly to the tv via hdmi, then take the optical audio output from the tv back to the receiver.
Jan 04, 2013 | Yamaha RX-V595 Receiver
I have a Denon AVR-3803 receiver and I have a DirecTV HD DVR HR 20-700. We believed someone hit a button on the receiver to cause the screen to go black. What buttons should we be pressing to try and...
First thing would be to check all the input settings on the TV and Receiver. Without knowing how it's connected, follow the cables from the Direct TV receiver to the AV receiver then to the TV and note the location. (input name) on the electronics back panel. Then make sure the TV is on that input, (Video1, Video 2, etc) Same on the AV Receiver, make sure the name on the back of the unit where the video cable is plugged into is displayed on the front of the Receivers display (CBL/SAT, HDTV, etc.) Lastly, make sure all the products are "on" especially the Direct TV receiver. It happens! Hope this helps. If you still have an issue, post a comment/reply and I can help you further diagnose the problem.
Jun 01, 2011 | Denon AVR-3803 Receiver
I can't get video out to TV from Wii video input on receiver. Wii is connected to AV5. Video to TV is thru HDMI out on receiver to HDMI in on TV. I can port the audio but get no video
Hello there,
ok the setup you are using is a Receiver, TV, and Wii unit .
Step 1: plug one HDMI cable into the back of the Receiver unit on slot 2 name on it is called HDMI out jack
if looking at the back of the unit this slot is 2nd from the top left
Step 2: now plug the HDMI cable into the TV this is the cable you just plugged into the Receiver
TV done
Step 3: Wii Setup move the Yellow,White,Red cables over to the right if looking at the back of the unit 2 spots name for this group is called AV out Jacks .
Wii Done
now use the right input channel for this group and you should now See Wii playing .
Thank you and don't forget to Rate
Jan 26, 2011 | Yamaha RXV467 Receiver
How do I set up my Panasonic Viera to connect via HDMI to my Direct TV receiver?
Cliff, it al depends on what kind of DIRECT TV receiver you have, if it has an HDMI port on the back of the receiver then all you have to do is plug it in and change the input on your TV to HDMI
Enjoy thats a great TV
Dec 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
Dead unit
I'm sorry to hear about your DISH Network DVR-625 receiver. If you don't mind me asking & to allow me to further assist you, what exactly do you mean by "dead unit"," For example, was it working and has suddenly stopped working? Does it power on, can you see any lights on the front of your receiver? Is it plugged directly into a electrical outlet on the wall, or is it plugged into a power strip/surge protector? If plugged into a power strip/surge protector, please attempt to bypass by plugging the receiver directly into an electrical outlet- if plugged into an electrical outlet please try a different outlet. I hope these few tips may help but if not and you need further assistance please feel free to contact me @ Kirstie.Filosa@Dishnetwork.com :)
-Kirstie DISH Network
Oct 03, 2009 | DISH Network DVR-625 DTV Receiver /...
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
Probles with dual screens on sat. receivers
if both receivers are plug into their own inputs on the back of the television, go into the remote set up screen and program the av1 or av2 as a seperate receiver. this will all the remote to send a different signal to the receivers so they wont change at the same time.
Jan 03, 2009 | Televison & Video
How do i hook up my ILO TV to direct TV satelite?
i have a ilo 32 in hdmi hdtv and i have mine hook up to direct tv .on the back of the receiver plug your red,white and yellow into the audio 1 of the direct receiver. on the back of your ilo tv plug the other end to the av1 and use S-VIDEO ALSO. plug the sat cord to the ant.in. on the tv set remote hit video and go down to s-video and hit ok. you need to plug all three plugs into their color ans the s-video too in the AUDIO section. mine works great !
Dec 30, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
