Question about Tomtom GO 300 GPS Receiver
Tomtom go 300
300 tomtom go, we have 12 volt charge by mistake, there was a audeur burns.
There is a piece (transistor), or it's written LM? ,
But I can not read a result of writing because the piece is damaged.
  • 158 Answers
Its likely to have blown IC's 24 , 25 and also sometimes possibly 26. You might also have blown the reverse polarity protection diode. Tomtoms damaged this way require a specialist repairer as the solder joint are much too small for the average electronics guy to solder. If you have no knowledge of this type of soldering or if you have not got the special soldering equipment then it will have to go to someone who has repaired these before or go back to TomTom for repair.
Posted on Jan 29, 2008
Installed new rheem 40 gal elec water heater. model ge40m06aag. no hot y already checked breaker and am getting. 240v to the wh
did you turn the power on BEFORE you filled it with water???
this is a pretty common mistake. you will need to check the upper element to make sure its working.
most water heaters have an upper and lower themostat. the upper thermostat is the one we need to check.
use your volt meter...
turn the power off, test with your volt meter to make sure! remove one wire from the element, not the thermostat, and check resistance on the element. if no resistance, you burned the element, and will need to replace it.
replace with same wattage, usually 4500watts. it will be written on the element.
also, I like to push the reset button on the thermostat to make sure it wasn't tripped.
Aug 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hi i put a 12 volt charger by mistake into tom tom now it wont come on any ideas thanks
You will need to send it to Tomtom now -it most likely fried the hdd.
May 06, 2010 | Tomtom GO 700 GPS Receiver
Wil not turn on
Put the receiver in the charging cradle. Does the green charging light appear? If it does not, you might just have a defective cradle and hence a completely flat battery; try charging with the car charger and retry. If it doesn't charge with either charger, the power section of the TomTom is obviously gone.
Assuming you now have a charged TomTom, keep the power button pressed for five seconds. If it does not turn on, try resetting it by inserting a paper clip in the RESET hole hidden below the front cover.
If it still does not turn on, it's either a defective power button or a faulty mainboard, and I'm afraid you can't easily fix either; you'll have to send it to maintenance.
Let me know how it goes...
Mar 15, 2010 | Tomtom GO 910 GPS Receiver
Over loaded via 12volt mains adaptor
at great expense cheaper to buy a new one
Jul 31, 2009 | Tomtom RIDER GPS Devices
My 1 year old tomtom will not pick up satellite signal
couple of things, battery not fully charged (AC)
No view of the sky
burned out SIIRF CHIP
Jun 18, 2009 | Tomtom ONE GPS Receiver
I have a tomtom one 3rd edition, charged it up for 4 hours and it doent work tried reset and it still dont work
TT one's are famous for the car adapter going bad and supplying more than the required 5 volts to charge the tt. Unfortunatly the result is a burned componet on the board. If it is less than a year old here in the states and you you have your receipt contact TomTom for a replacement. If you don't have a receipt then you have a paper weight. It still has some monatary value, sell it on ebay and people will bid on it for the parts.
Apr 30, 2009 | Tomtom ONE 3rd Edition GPS
I have had my tomtom one XL for almost one year. The car adapter (charger) cord went bad and they were backordered on the tomtom website so I purchased a radio shack universal adapter for navigational...
More than likely the generic charger sent more than 5 volts to your tt and burned a few rectifiers. You could try and tell tt the original charger did this but if they say no you are out of luck. You could put it on ebay and get something for it.
Apr 19, 2009 | Tomtom ONE XL GPS
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
TomTom 510 Sat Nav
Most likey its not worth fixing. Look at it like this. While it may have only been 6 volts versus 5. One volt in a 5 volt system is a 20 percent increase.
If you took something that ran on 120 volts and plugged it into a 144 volt source you can figure the damage that would do.
Mar 22, 2008 | Tomtom GO 510 GPS Receiver
Tom tom not working
  1. First , try a re-set through the 'reset' hole underneath the tomtom. 1 quick short press is all thats required. Unlike others suggest , you do not need to hold it in for anything longer than half a second. You should feel the switch 'click' as its a tactile switch. Don't press too hard as you can damage the switch and cause it to lock ON. Once pressed , try turning the tomtom on as normal. Sometimes a tomtom battery can drop below its normal "shelf" voltage ( normal is about 3.8 volts ). A tomtom charger has a protection circuit inside to stop or slow the current it gives out if there is a short. If your battery HAS dropped volts TOO MUCH ( less than 3 volts ) the charger can "see" the tomtom battery as a "short" and the charger therefore shuts down and doesnt charge the battery. You could leave the charger connected and HOPE that the very small amount of current it's putting out will eventualy bring the battery up over 3 volts. Once it is up near its "shelf" voltage ( called shelf voltage as that is the voltage the battery is at 'on the shelf' ie . when its not powering anything ) the charger will begin to charge as normal....... OR ... you can gain access to the battery and charge it from a bench power supply that has voltage and current meters. Once again , once the battery voltage gets something near 3.8 volts the normal tomtom charger can be used to charge it. You caould connect another normal battery to the tomtom battery just for a few seconds ( not recommended and can be a bit dangerous ) if the normal battery is such as a PP3 9v type it should bring up the tomtom battery to over 3.8 volts in a few seconds. The tomtom can then be charged as normal. .............. It is also possible that some internal IC's ( chips ) have blown inside the tomtom and unfortunatly this would require a specialist repair centre to replace them as they are really very very small and are not a normal soldering job. Good luck. ... if this post has helped you or interested you please rate the author.
Jan 12, 2008 | Tomtom ONE GPS Receiver
Tomtom GO 300 GPS Receiver Logo
128 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
