Question about HP Pavilion dv2715nr Notebook
My display works for a few mins then goes out, but displays fine on a external monitor
  • winsto_n Dec 29, 2009
    I dont think thats the problem... the screen is intermittent... sometimes it works for hrs and its not the connection or conductor because i have moved the screen back and fwd without any effect.
    Novelist:
  • 195 Answers
Depending on how handy you are... my friend ordered a replacement LCD screen for laptop and self-installed. Check ebay or other on-line sources for part.
Posted on Dec 12, 2009
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
Screen goes into standby mode after a few seconds. Screen will not stay on. Started after the computer was on and coming out of standby mode. Computer works fine on external monitor.
Depending on the options you purchased the laptop with, it either has an integrated video circuit into the motherboard or a plug-in video card to the motherboard. If the laptop works fine with external monitor, your motherboard or video card is defective. Your LCD display is probably O.K.
Jan 04, 2011 | Dell Inspiron 710m Notebook
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Blank screen,pwr sup appears to ok, fans runs, pwr light on
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
May 26, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
Display problems with dell xps m1530 laptop
These models have known video card problems, so first thing connect an external monitor before booting - boot and see if the image on the external monitor stays on, if it's fine on the external monitor then the LCD panel might be defective, otherwise if you see blurred / distorted image on the external display it's the VGA card. which means you should contact warranty (if you still have) because the mainboard needs servicing / replacement.
May 25, 2010 | Dell XPS M1530 Laptop
It displays colorful lines on the monitor...cant see nothing
Test your laptop with an external monitor and find out if the external video goes bad too. If both, internal and external images go bad, you have a problem with the video card.
If external works fine and only internal goes bad, most likely it’s either bad video cable or LCD screen failure.
May 21, 2010 | Nvidia GeForce 7200 Graphic Card
I've got a Dell Inspiron 1525. When I power on the unit, the LCD shows the Dell startup screen, then a whinning noise and the screen goes black. Sometime shortly there after the Windows screen appears but...
This sounds more like a hardware issue. Now you say that the external display output is working fine. It could possibly be a problem with the lcd display itself shorting out. If there was a problem with the video hardware then I do not think you would be able to get the external display working either. The whinning noise could be coming from the lcd inverter.
Dec 14, 2009 | Dell Inspiron 1525 Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Monitor does not display picture. If i turn off and turn back on it displays screen for only 2-3 seconds then goes black?
Plase update Display/graphics driver.
If you have a external monitor try plugging into notebook, if the external monitor works fine, you can replace the display.
>Check in safemode>If its stays for long time, it could be an issue with Virus.
>Check in BIOS as well
>If the external monitor is also acting in a same way, you may have replace the system board
Jun 30, 2009 | Computers & Internet
HP Pavilion dv2715nr Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
