Door will not latch - Washing Machines
    Scholar:
  • 66 Answers
If your door wont latch it just means that the latch itself is either bent or broken. Either way you cant repair the latch itself so you'll have to have it replaced. Without knowing what kind of machine you have i cant instruct you on how to replace the latch so either repost with that question and the type of machine ie: front load or top load, or get a pro repairman to come and replace it for you.
Posted on Dec 12, 2009
  • 11,896 Answers
It is likely the latch itself is broken or else the machine is in the locked position. If the switch is broken, replace it. You can get one at repairclinic.com or partselect.com
If the lock is on, disconnect from power source (unplug machine) for few hours, press and hold start/cycle button for 3 seconds and wait half hour more and pllug back in.
So I close my car driver side door and it automatically says on the dash board that my door is open?? Any suggestions on what might be wrong. Its a 2011 Ford edge if that helps at all. thanks
Your door ajar system is tied into the door latch mechanism. if the door still appears to close tightly, and the door latch works properly, then you may need to adjust or replace the latch, though ford has listed a cleaning procedure for the latch that involves using a tool to test latch position and manually closing the latch (while door is OPEN) using a screwdriver 10-20x and monitoring to see if the latch consistently shows CLOSED and OPEN when it should.
If pushing the door closed after its already closed causes the lamp to turn off, an adjustment of the latch may help, or cleaning the latch contacts may also help. If the door never shows latched regardless of how hard it is pushed, it may be a defective latch, or a wiring problem (Door wires sometimes break in the door harness between the door and the side of the dashboard when the harness enters the vehicle).
Feb 24, 2015 | Ford Cars & Trucks
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
HI,MY DISHWASHER DOOR HAS BECOME VERY STIFF TO OPEN ALTHOUGH IT CLOSES WITH NO PROBLEM. when I looked underneath the door grip handle, there's a little white thin skittle shaped pin .,......when I push...
Hello
Open the dishwasher door and inspect the latch mechanism for obstructions or immovability.
Clean out the door latch with a stiff bristled brush, and apply lubricant. Open and close the door to see if it now latches shut.
Check the door latch and strike plate alignment. Close the dishwasher door slowly and observe the door latch meeting the strike plate. Determine whether the latch is striking the plate correctly. If not, use pliers to gently bend the latch to meet the strike plate.
Gently hammer the latch to better align with the strike plate. Hammer carefully so as not to break the latch or dislodge it from its attached point. Open and close the door to see if it now latches.
Realign the strike plate. Loosen the strike plate with a screwdriver and slightly move its positioning to better align with the door latch. Tighten the strike plate and open and close the door to see the results.
Sep 07, 2011 | Dishwashers
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Mar 24, 2009 | 1997 Lincoln Continental
Washing Machines Logo
131 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
