Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
Hotpoint Ultima Super Silent. Wash & Dry 5+5kgs ModelWD860P
S/No 7100 10050
Date of Purchase 17:10:07
We are having a problem on the drying cycle, and the error message on the display is E13 can you shed any light on the problem please.
Thanks
Dave Unwin
  • ASHLEY Jan 27, 2013
    washer is leaking - how do i get the red cap off to try and clear the drain
    Sergeant:
  • 160 Answers
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Posted on Dec 18, 2009
Hi, i have washer / dryer "Hotpoint Ultima Super silent WD860" with an error code F13 when trying to use the dryer Please advice Thanks
Check the water supply, inlet valve, and hot & cold hose connections.
Got this piece of advice from their site..
Hope this helps.. :)
Jun 10, 2011 | Hotpoint Washing Machines
My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
Jul 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Error Code "TEST"
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
May 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent wash wt 960
i rang the service engineer and they looked up the code, it was something to do with overheating, they are sending someone to fix it soon!
Dec 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
367 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
