Question about Projection Televisions
Hitachi Projection tv 1995
Hello Team,
I have an old Hitachi Projection Tv (95) that is experiencing some problems...For example: when i'm watching jumps in and out of doublevision (distorted vision and double person picture) then when I hit the tv it goes back to normal....What is this? How can I fix it? what part do I need to fix? Your thoughts
5 Suggested Answers
  • 8617 Answers
SOURCE: 61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
Posted on Jul 17, 2008
  • 899 Answers
SOURCE: Double vision with redness
convergence IC's need replacing, and testing of resistors on them
Posted on Dec 10, 2008
  • 8617 Answers
SOURCE: My RCA projection TV is showing double vision
You can get the STK730-130 convergence IC at the following link which should take care of that issue. Its 24.00
Posted on Jul 13, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi Projection TV 57F500A red looks double.
You need to replace both of the convergence IC's and any bad resistors around them that protect them from damaging the power supply.
This repair can usually be done in the home and takes about an hour; I have done hundreds of them and now is a slow time of year for TV shops; look around if you are not able to do this repair; you can buy the chips on Ebay for less than 15 dollars for a pair plus shipping.
This is a very common problem in projection sets.
If this has helped you give me a vote here as I do this for free. If you have questions or need help:
Posted on Aug 23, 2009
  • 3459 Answers
SOURCE: the image looks blurry, distorted almost like doub...
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from
Posted on May 30, 2010
0 characters
1 Points
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 04, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V710 Greenish Tint
Make sure that there is no Magnetic feild around the LCD
Sep 06, 2008 | Hitachi 50V710 50" Rear Projection...
Ours is 2 yrs old.TV turns off by itself every 2-3 min.
U replaced the projection lamp the last 2 years?U used the tv on and watches 4 or 5 hours a day?Yes,the tv projection lamp life is over.Require changing a new projection lamp.
Aug 03, 2010 | Hitachi UltraVision 60VF820 TV
The bulb on my Hitachi Projection TV went out a second time. We just recieved the replacement. We still see a red hue (big circle) in the middle of the screen when the tv picture fades during a commercial....
hey I have a zenith projection tv that is only 3 years old and i have already replaced the stupid bulb 3 times at 450.00 a pop. No one told me at the time that i bought this tv at best buy that this bulb would have to be replaced this often. and the bad thing is i never watch this damn thing anymore but i paid 2200.00 for a tv that i cannot afford to watch and zenith will not help me at all with this problem
Feb 19, 2010 | Hitachi Projection Televisions
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV wont stay on
Sounds like a short somewhere in there. I see old pre-HD big screen sets going for well under $200 on my local craigslist, so look there for a good replacement, because the repair will cost more.
Or fork over about $500 for a good used HD projection set.
Apr 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10b Convergence
you must be experienced technician to do this if you are not will mes up your tv there is a service mode that you can access by pshing a service buttom located in front of digital convergence bord afther the aligment is done you have to reinitialize sensors and save to eprom for this service manual is needed
Mar 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
This can be one of two problems. 1: convergence output ic's need to be replaced. 2: The problem is in the power supply, most likely a power diode.
Both problems you will need to take it two a repair shop.
Mar 15, 2008 | Hitachi 57TWX20B 57" Rear Projection...
Projection Televisions Logo
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
