Question about Belkin F1DF102PEA 2-port KVM Switch
No Keyboard or mouse function using a Belkin Switch2 F1DG102U
Hi I have a problem with a Belkin Switch2 F1DG102U KVM. The keyboard and mouse do not work on either machine i try to use. The first machine is a Fujitsu PC the 2nd is a dell laptop both running Xp. I can change video and audio between machines using the remote and hotkeys but not the keyboard or mouse. I've tested the k/board and mouse directly into both pc's and they work fine but not through the KVM - all devices are USB.
Thanks in advance
  • 4 Answers
SOURCE: Belkin (F1DK102P) 2-port KVM Switch freezes
switch connections from pc1 to pc2 and boot up pc 2 first make sure everything works and then boot up pc 1 wait 2-3min then tre the switch
Posted on Dec 20, 2007
viaujoc
  • 60 Answers
SOURCE: Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Posted on Feb 08, 2008
Sphynkter
  • 221 Answers
SOURCE: 2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
Posted on May 16, 2009
SOURCE: Components not recognised automatically with Belkin Switch2
This is not quite a solution, but a workaround. Take a USB cable extender and intercept the 5V supply wire in it (normally red) with a push to break switch. When you have powered up the PC, push the switch and the KVM will then work (same as your unplugging but much easier to do ). Switch bought on Ebay for 0.99GBP. Belkin tried to insist that I had my laptop plugged in and working if I wanted to use my desktop.
Posted on Aug 18, 2009
Zphinx
  • 60 Answers
SOURCE: just bought a 4 port KVM and hooked it up and the
is that a Mouse/keyboard combo ? If so, try with a standalone Mouse and a keyboard. If the Keyboard and Mouse need Special Drivers the solution might not work neither.
I hope that helped.
Posted on May 12, 2011
How do I connect a usb mouse and keyboard to ps2 kvm switch?
usb to ps2 converter, the sell them for like 30$ but you can go to radioshack and buy a keyboard for that with the little adapter
Mar 30, 2013 | Belkin F1DL102P 2-port KVM Switch
COMPUTER KVM
the belkin needs a driver for win 7
Nov 22, 2011 | Belkin Computers & Internet
One computer is allowing the keyboard and mouse to be usable while the other is not. This problem happend about a year and a half ago and didn't come up again until I moved to a new warehouse and now it's...
remove old drivers and update them with new one by following this link
this allows you to use additional options....
http://tinyurl.com/f1dg102uuk
also you can download the quick installation guide found in the link above....
Apr 20, 2010 | Belkin F1DG102U 2-port KVM Switch
Power light went off
No, the switch is powered from the keyboard connection on your computer.
Feb 01, 2010 | Belkin F1DG102U 2-port KVM Switch
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
Feb 08, 2009 | Belkin F1DF102PEA 2-port KVM Switch
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
BELKING SWITCH2
I think you must also connect the USB connectors.
Jan 24, 2008 | Belkin F1DK102U 2-port KVM Switch
Belkin 2-port kvm switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
Belkin F1DF102PEA 2-port KVM Switch Logo
215 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
