Question about Motorola Mobility W375 Cellular Phone
Hey i have this problem my screen turns on but stays blank with little faint vertical lines barely visableit is a Motorola W375
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
Hey i have a Toshiba Equium M40X-148 and the screen wont turn on. When i power the laptop up the power light lights up but the screen stays blank. Any ideas on what the problem maybe
If you tilt it to the light, do you see a faint image?
Can you connect the laptop to a external monitor and toggle the FN + F5 key to adjust monitor settings to output to the 2nd screen.
Feb 10, 2011 | Toshiba Computers & Internet
Text messaging input problem
on v3 you press and hold 0 (zero) to enter new line
Mar 02, 2009 | Motorola Mobility W375 Cellular Phone
Garmin GPSmap 76 locks up once satellite acquisition is complete.
Does the screen go blank with a faint vertical line (top to bottom)? If so, I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Oct 13, 2008 | Garmin GPSMAP 76 GPS Receiver
Open moto w375
Hello there. the motorola w375 cannot be openlined unless hacked. and that is not a route to go down.Thank you!
Jun 02, 2008 | Motorola Mobility W375 Cellular Phone
Donloading polytonic ringtone in motorola w375
Well go to a site that has a polyphonic download link because you are not going to find a mp3 that is lower than 1.5MB if you can then you have got yourself an mp3. i recommend www.waptrick.com for ring tones but go to this site using your mobile phone.
Apr 30, 2008 | Motorola Mobility W375 Cellular Phone
Screen not working
Dear Sasselle98,
The problem can and probably is hardware related and will need repair. (flex cable, lcd screen etc)
Nevertheless since the phone is only 6 months old it is under warranty and will be fixed at a motorola repair service center. So do that since it is the manufacturer's fault!
Regards
Mar 12, 2008 | Motorola Mobility W375 Cellular Phone
Screen stays blank
take the phone to a mobile service cener and have them replaced the flexcable for you that should correct the issue.
Aug 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility W375 Cellular Phone Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
