Question about LG Vu CU920 Cellular Phone
Water got in phone,now it powers up but screen blank
Mp837 water damage blank screen
Put your phone into a zip lock bag with dried rice this will pull the moisture out after a couple days.
Nov 11, 2011 | Cell Phones
The top of my nokia 5230 got dropped in water and now the screen is blank but it still switches on. what can i do to get the screen back again
Open up the phone and dry it in the sun, or do a blow-drying. Ensure that every trace of water is out of the phone. Then try switching it on. If the screen still appears blank, then the water must have severed the connection between the board and the screen. Open up the entire phone (screws and all ) and first with a soldering pin, melt off totally the solder initially joining the screen to the board, then re-solder it.
I hope this helps.
Mar 20, 2011 | Cell Phones
My blackberry screen sometimes works, it powers up but the screen is either blank or the keyboard goes fuzzy and out of control. is it a water damage?
You can check if it water damaged by taking the battrey out, you should a white box this will show no water damage but if shown as pink then the handset is.
Hope this helps
Feb 08, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Blank Screen
The flex of your phone is bad since it gives blank screen.
All you need to do is to change the flex of your phone and you will see that your phone screen will display.
Take care.
Apr 25, 2010 | Samsung SGH-E900 Cellular Phone
Wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
May 31, 2009 | Cell Phones
Blank screen
i had this problem before...i had to go to verizon and get a new phone
Nov 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG8300 stuck vibrating continuously, now main screen blank
Sounds like water damage. Are there any red stickers under the battery? If so, then it is water damaged.
Either way, if you are the primary line then Verizon may offer you an early upgrade if your rateplan is above a certain price point (if that's who your on). If not, you can do an insurance claim, if you don't have insurance then you will have to either pay full price for a new one, or purchased a used one.
Hope this helps,
Simon.
Nov 17, 2008 | LG VX8300 Cellular Phone
Blank Screen
Most likely phone was water victim :)
Open and clean, dry... Or take to nearest repair centre.
Jul 28, 2008 | Nokia 6300 Cellular Phone
Blank screen
can be the flux contect(lcd to pcba flux)loose
can be debug by-assble again the flux
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they will usually come with instructions and the screwdriver you need. A T6 torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
Jan 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
LG Vu CU920 Cellular Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
