Question about Panasonic Palmcorder PV-GS14 Mini DV Digital Camcorder
I can't get the cassette compartment on my panasonic PV-GS14 to close or accept a tape
  • claybo008 Dec 17, 2009
    Thanks for your suggestions Rylee!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This issue arises when the Camcorder is not operated for a long time.
Gently knock on the push button simultaneously opening the cassette holder and insert the cassette. Now push on the right side and gently push the holder back in position and press play, fast forward and backward one by one. The Camcorder will now accept the cassette. If still the issue persists, then repeat the above steps until the issue is resolved. It is recommended that always store the camcorder in a dust and humidity free area and always remove the battery and cassette when not in use.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 14, 2009
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
Panasinic PV-GS300 Will not accept Tape. Immediately ejects new tape
Hi there, you should spray inside cassette compartment a contact cleaner spray carefully aim on the upper right position there's a cassette in sensor ,maybe needs contact cleaning.if problem continues the mechanism unit must be replaced,only drum has a part nr all the rest goes as a unit with only one part nr.
Nov 14, 2009 | Panasonic PV-GS300 Mini DV Digital...
When trying to play a tape the tape shows lines through it. Anyone know how to fix this?
You may need a MiniDV head cleaner tape. Read the instructions on the tape carefully and good luck.
Sep 25, 2009 | Panasonic Palmcorder PV-GS14 Mini DV...
The tapes In my Panasonic PV-GS14 are stuck and won't run
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
May 09, 2017 | Panasonic Palmcorder PV-GS14 Mini DV...
I have a Panasonic PV-GS14 and it ALWAYS says 'Push Reset Button'
I had the same problem. In desperation, I picked up my trusty can of compressed air and aimed a few shots into the recorder/playback mechanism. Worked like charm.
Feb 18, 2009 | Panasonic Palmcorder PV-GS14 Mini DV...
Removed mini dv tape, reinstalled mini dv tape... cassette wont close, all power lost!
internal power supply fault, unit needs to be checked by a panasonic technician.
Jun 13, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Push the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
Jan 10, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
Tape Jam
Can anyone give any information on this problem? I am having the same problem, on Christmas of all days. Any help would be much appreciated. Thanks
Nov 23, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Nov 13, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Panasonic Palmcorder PV-GS14 Mini DV Digital Camcorder Logo
111 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
