Question about AMT Datasouth ACCEL-6350 Matrix Printer
SETTNG UP AUTO FORM FEED ON A ADP 6350 PRINTER
4 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: I cannot get the printer to form feed, it only manual feeds, how
I take it what you're saying is that you have to feed paper via flipping out the front tray and then pressing "online" or "continue", and that it will not feed paper from the actual paper tray?
You can try to take the beast apart and see why the control panel is not functioning, but I'd sit it on the curb, as it was probably manufactured sometime between 1993 and 1997. time to let the old girl die.
Posted on Mar 05, 2009
  • 40 Answers
SOURCE: form feeding
try puting a piece of cardbord under the paper but tape it 3mm from the roller.
Posted on Jul 31, 2009
SOURCE: my adp 6350 printer just
It may be something as simple as a connection to the control panel Give us a call if that does not work 515-440-2330
Thanks!
Posted on Aug 03, 2011
HOW DO I REALIGN MY ADP 6350 PRINTER
Not sure what you mean by "realign" but you can try under the test menu select pcalb. make sure there is not paper installed and the printer is not in direct sunlight.
Nov 14, 2013 | AMT Datasouth ACCEL-6350 Matrix Printer
Amt 6350 setup
your printer is locked up of some functions. to unlock hit alt and form feed then setup twice.
Jan 20, 2012 | AMT Datasouth ACCEL-6350 Matrix Printer
HOW DO I ADJUST THE TOP OF PAGE FOR A FORM?
when the paper loads, the top of form is then set., If the printer is not setting this or the paper just feeds through when loading paper, go into the test menu, select pcalib and make sure no paper is in the printer. aslo make sure the printer is not in direct sunlight. this will reset your paper detection circut and therefore your tof "alignment"
Sep 07, 2011 | AMT Datasouth ACCEL-6350 Matrix Printer
My adp 6350 printer just went dead on me. if i power on and off the printer makes noise but the display won't come on and i can't feed paper in or print.
Thanks!
Jul 30, 2011 | AMT Datasouth ACCEL-6350 Matrix Printer
AMT 6350 printer. 'error' light keeps blinking with 'load paper' flashing. put paper in, press form feed, did not help
Perform "Pcalib". Under the test menu select pcalib. Insure the printer has no paper installed and is not in sunlight. This should fix it.
Jan 27, 2011 | AMT Datasouth ACCEL-6350 Matrix Printer
The printer will not feed forms. I replaced the line feed motor but that didn't fix it
platten driver on board most likely is bad. the driver the on the brass colored heatsink and is the one to the far right. With a multi meter set to ohms, check the diodes in front of the far right driver. Resistance shoud be real high on each one if on is low, replace driver. IC is a L298
Nov 04, 2010 | AMT Datasouth ACCEL-6350 Matrix Printer
PRINT GAP WHEN SET ON AUTO IS TOO CLOSE. (RIBBON SMUDGES ON PAPER) WHAT DETERMINES THE STARTING POINT FOR THE GAP ENCODER? DOES THE PAPER SWITCH ON THE CARD GUIDE HAVE ANYTHING TO DO WITH IT?
enter the hidden menu. press setup and scroll to end #52. press and hold form align and config. scroll to 58 gap adjust lower the number the closer the gap is.
Jun 17, 2010 | AMT Datasouth ACCEL-6350 Matrix Printer
Form feeding
Jul 31, 2009 | AMT Datasouth ACCEL-6350 Matrix Printer
AMT Datasouth ACCEL-6350 Matrix Printer Logo
341 people viewed this question
Top AMT Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an AMT Office Equipment and Supply Expert? Answer questions, earn points and help others
