Question about Frigidaire FEB27S5A Electric Single Oven
Something popped in back and now no heat in oven. no error codes, everything seems to work, but no heat.
  • Frigidaire Master
  • 3,463 Answers
If it is a fan assisted oven, and the fan is working o/k, then you probably need to replace the oven element, this is located at the rear of the oven, behind a removeable cover.
Hope this helps you.
Posted on Dec 12, 2009
Error E7 : F1 GMC275PDs07. Microwave works normally but will not heat. Magnetron changed out and still will not heat.
If your microwave is a 220 then reset the breaker by turning it off for 10 seconds and then back on. Then check it. Since you replaced the magnetron, the signal to the mag is interrupted. Did you replace the control panel? If so, then look to see if it is wired back in order. Does the fan operate when you open and close door? If not, then check door switch.
Feb 24, 2013 | Whirlpool GMC275PD Electric Double Oven
Thermador SCD302TB wont heat. first upper, now neither
If it is any help to you, you can get a new controller board complete on ebay for aroung $190. Not much left after that besides elements...
Mar 01, 2008 | Ovens
I used the self clean cycle and it has cooled off now getting error F5E1 and won't unlock? Please help. I use my oven almost daily!!
F5-E1 is a door lock error. Depending on the extent of the error, a hard reset may recycle the door lock and allow you to use the oven. Turn off power to the oven for 2 to 5 minutes and then turn the power back on. Give the oven about 2 to 3 minutes to possibly reset.
If the error code returns, there a few different problems you may have.
  1. The door latch mechanism could be broken or shorted
  2. The may be a pinched or shorted wire
  3. The Oven Control Unit may be bad
If further assistance is needed, please submit the brand and model # of your oven
Apr 15, 2011 | Ovens
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
GE electric double oven
Colin, the TCO is located on the back of the oven. It will open L2 to the heating element in the event it is open. If this TC0 opens it will not show any error codes. This is for the 27 inch wall oven models only. Catriver...post back.
Nov 09, 2006 | GE JTP48 Electric Double Oven
Frigidaire FEB27S5A Electric Single Oven Logo
98 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
