E-Machines eMachines Desktop PC Logo
Posted on Dec 12, 2009
I cant back up my files,Iget COM Surrogate stop working,RPC Server is unavailable and I cant download anything on my computer
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
4439
Points
31
Rather than backing up to a CD. Image the whole drive.. RPC Server is a system service and may be failing due to a number of reasons. Here’s a link to Microsoft to Technet if you want: http://technet.microsoft.com/en-us/library/cc738291(WS.10).aspx
If I diable com surrogate will it harm my computer
Com surrogate is a service that allows switching on the com ports. Without it, communication to your devices will stop. If you're encountering this error there is a driver problem with your com port controller and you need to install the correct drivers.
Cant install driver with "rpc server is unavailable" and also shows both the se and se sec family in device manager.
INFORMATION SOURCE CREDITS TO >>
http://ezinearticles.com/?How-to-Fix-RPC-Error-When-the-RPC-Server-is-Unavailable&id=3298701
Have you gotten an RPC error lately? They look a little like this:
- "RPC Server is Unavailable"
- OR "The RPC Server is too busy to complete the task"
- Here's the best one, "Access denied"
This is fun stuff. Unfortunately, an RPC error is one of the most common errors out there, and most of us don't even know what RPC is.
What is RPC?
RPC stands for "Remote Procedure Call." This probably still doesn't tell you much. Let's see if we can put this in non-technical language. RPC is the go between of your computer and server. This is what allows your computer to access a network.
RPC has two main parts to it: the client and the server. When the client (the program requesting something) sends a message to the server (the process that takes the order or performs the task), it is being asked to execute a certain procedure. The client waits for the server to process the call before resuming the execution.
Why Won't the RPC Server Work?
Usually, the RPC error pops up because there is some sort of miscommunication between the computer and the server. Most of the time, the wires get crossed somewhere due to Internet components that are not configured or activated. Sometimes it is just a matter of adjusting the Internet Firewalls or Proxy Server.
Quick RPC Error Fix
One way to investigate an RPC server error is to verify that you have enabled the DCOM Tunneling is enabled and not being blocked by any third party Internet Security programs such as AVG, Norton, McAfee, etc.
To do this:
1. Go to Start and Run
2. Type in DCOMCNFG
3. Click on Component Services
4. Click on Computers
5. In Computers, right click My Computer
6. Choose Properties
7. Go the Default Properties tab
8. Check the "Enable DCOM" tab
9. Go to the Default Protocols tab
10. Click Add
11. By the Protocol Sequence move the down arrow to Tunneling TCP/IP
12. Click OK
13. Click MoveUp button until Tunneling is at the top of the list
14. Now you may select SPX and Remove
15. Click OK or close the program out
16. Restart the computer
When You Need Help with the RPC Error
The RPC Error is such a common error, it seems like it should be easy to fix. However, the DCOM Tunneling fix is only the beginning of troubleshooting an RPC server error. The good news is that you really don't have to do anything when it comes to an RPC error if you maintain your computer with registry maintenance tools. Try researching the benefits of a registry cleaner to fix RPC errors.
Optimize-Your-PC, with its Advanced Registry Cleaning Technology, will repair an RPC error, and Speed Up Your PC, all in under 2 Minutes.
ALSOP TRY DHCP CLIENT RESET
HI While installing Vedio driver is trowing RPC server unava
Hello sans_sankar,
If it says RPC server is unavailable, that has to do with your internet connection.
Check if both ends of your ethernet or USB cable are properly plugged in their ports on your modem or router to your computer.
You can also turn the modem or router off for a minute then turn it back on again.
Your video installation should be complete, otherwise, it might be incompatible with your computer.
Hope that helps.
Yours truly,
Art Pena
1helpful
Cannot use WinXP System File Checker (SFC), RPC Server?
Are you trying this in safe mode?
Sometimes the RPC service will refuse to start. Assuming all other services are reset to their default values:
Start, run, CMD
net start (check the service again to be sure it is stopped)
net start rpcss
net start (check again)
if no joy, you need to use the XP CD to go to the Recovery Console.
From the Recovery Console type:
enable RpcSs SYSTEM_AUTO_START
reboot the machine.
"Could not start the Remote Procedure Call (RPC) Service. Error 1058" error message when you manually start the Remote Procedure Call service
http://support.microsoft.com/?kbid=838428#appliesto
Some general things to try.
See if System Restore will get you back to a restore point before your problem with Explorer.
Try Safe Mode (Do you have this problem in Safe Mode?).
Try running ChkDsk to check your drive for errors. Right-click your Drive icon/ Properties/ Tools/ Error Checking. Select both boxes.
Run the System File Checker program from the Run Box by typing.....Sfc /Scannow in it and have your XP CD handy.
HOW TO: Verify Unsigned Device Drivers in Windows XP
http://support.microsoft.com/support/kb/articles/q308/5/14.asp
If they don't work you could try repairing windows by running it over itself. You will lose all your windows updates but your files will be untouched.
How to Perform an In-Place Upgrade (Reinstallation) of Windows XP (Q315341)
http://support.microsoft.com/support/kb/articles/q315/3/41.asp
1helpful
2answers
I am trying to install the canon selphy ES20 printer...however when I attempt to add the printer to the computer, it does not recognise it and says there is an error with installation and "RPC server...
Hi, this is a solution for you. Follow the steps below and your Canon printer should be working.
  1. Unplug the printer from your computer
  2. Download and install the drivers from this link
  3. Plug in you printer and just let your computer recognize it and do it's thing.
Good Luck!
Greased
13helpful
Rpc server is unavailable
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Cant install printer to pc
Could be a corrupted file in your spooler folder:
Info from Microsoft:
To resolve this issue:
  1. Copy the Spoolss.exe and Spoolss.dll files from another Windows NT 4.0-based server or workstation to the %SystemRoot%\System32 folder on the affected computer.
  2. Apply or reapply the latest appropriate Windows NT service pack, and then restart the computer.
  3. Set the Remote Procedure Call (RPC) Service to start automatically:
    1. Click Start, point to Settings, click Control Panel, and then double-click Services.
    2. On the Service list, click Remote Procedure Call (RPC) Service, and then click Startup.
    3. Under Startup Type, click Automatic, and then click OK.
  4. Restart your computer.
2answers
RPC Service not running
Please restart the service of RPC.
Write the script for RPC services by the help of google ur problem will be shortout .
Regards
MAYANK GUPTA
2answers
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at [email protected]
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
