Question about Saws
The red saftey lock button will not lock blade in place how can i get the blade off? Ive tryed putting saw blade in a vice and then using socket wrench to loosen nut ive broke two sockets.
  • joughmac May 11, 2010
    saw make and model?
    Problem Solver:
  • 10 Answers
Chances are you are turning the nut the wrong direction. The old addage "lefty loosey, righty tighty" does not apply to saw blades. You must turn the socket "clockwise" to loosen, which is opposite to normal nuts and bolts. Try slipping a screwdriver between the teeth of the saw. It should catch on the shoe of the saw as you loosen the nut.
Posted on Dec 14, 2009
How you use and lock blade
There's usually a button on the housing to lock the blade. Unplug the saw first. Put pressure on the button while you rotate the blade by hand. The button will bottom out in the shaft, locking the blade when you reach the correct spot. You can now place a wrench on the nut to remove the blade.
Dec 20, 2014 | Saws
How do u remove the blade on a chop saw ls1013
Be sure the saw is switched off and unplugged. Use the Makita socket wrench on the side of the saw base if you still have it. If not make sure you use a socket or wrench that fits the bolts properly so you get them off and back on without damaging them. Lock the handle in the up position with the stopper pin. Loosen the hex bolt holding the center cover in place, this will let you raise the guard and center cover so you can get at the blade bolt. There is a button on the back side of the blade guard that locks the spindle. Push and hold the button in and turn the blade until it locks in place. Using the socket wrench, turn the blade bolt clockwise or in the same direction the blade turns while cutting to remove it, the outer flange and blade. Put the new blade on (check that the direction of the arrow on the blade is the same as on the guard), the outer flange and blade bolt. Use the spindle lock to get the bolt on tight. Return the center cover to it's original position and tighten it's hex bolt. Turn the blade by hand to make sure the spindle lock released then pull the stopper pin and make sure the blade guard works properly.
Feb 03, 2012 | Saws
How do I change the blade on a Craftsman 10"
Hi Tom, W/D here.
There are usually three different ways that blades are installed and/or removed. All require that the power be removed from the saw first (pull the plug, please).
1. The most common method involves a shaft lock, so look for this first. It will appear as a button on the motor, near the blade. When you depress the button, you'll need to rotate the shaft/blade by hand until the lock sets in place in the shaft. Then, while still holding the shaft lock button down, use a wrench to loosen the blade. (Look at the threads to make sure that you are turning in the right direction, as this may be reverse threaded).
2. Less common is a shaft that has an allen socket in the end of it. Place the loosening wrench on the not, then place the allen wrench in the end of the shaft.
3. If all else fails, you can, VERY carefully, wedge the blade down into a piece of soft wood such as pine, then loosening the blade with a wrench. Make very sure that you keep all of your bodily parts out of the line of fire when using this method, as the blade can turn suddenly, and you don't want to have anything caught up and cut by the blade.
Hope this helps, Best regards, --W/D--
Nov 04, 2011 | Craftsman 10" Table Saw
I have an older B+D circular saw, Model 7700 Type 1. I replaced the blade but when I tightened the retaining bolt, the blade spins freely and now I can not get the retaining bolt loose.
Quick and dirty solution for this is to use a drill bit or large nail in teeth of the saw to jam crosswise against the guard @.Or use a 2x4 clamped in place and jam the blade in to the wood to stop the blade.Just reread your problem.Sounds like the back washer came off.There are 3 things that may work.If you get some wooden wedges (shim pack,hardware store) put the thin ends together and the thick ends to the out side >
Jul 17, 2011 | Black & Decker Saws
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
I am trying to install a blade on a circular 18 vold cordless circular saw and cannot remove the bolt that holds the blade in place. Is there a way to lock it down.
some saws have a button to hold down that will lock the blade in place. if yours doesnt have the button, try putting a screwdriver in one of the cutouts or on the blade tip itslef and lock it in position. your problem may be that the screw on the saw is actually reverse threaded. they usually are reverse threaded.
Dec 24, 2010 | Black & Decker Saws
I lost the wrench to my hitachi g12sr3 grinder. how do i remove the wheel?
Place the grinder on a steady work surface and use a punch. So that you do not distort the nut find a punch that fits nicely into one of the holes. Hold the punch with vice grip and rap on the side of the punch close to the nut. One or two quick hits is all that you need. If the blade turns as you hit and the nut does not free, Either have a friend hold the lock button or lock the blade with two pieces of wood and vice grip (wood on each side of the blade and clamp on vice grip, then let turn till it hits one side of the guard. Good luck
Oct 08, 2010 | Hitachi G12SE2 4 - 1/2" Disk Grinder
How do I disengage the drive shafts to tighten a
should be a black button between the handle and the guard. Spin the blade until it depresses all the way down and you should be able to loosen the blade.
Dec 05, 2009 | Ryobi P501 18v Circular Saw Only
How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Mar 28, 2009 | Saws
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Saws Logo
97 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
