Question about Scytek Electronics ASTRA777 Car Alarm 1 Cf 2way LCD Remote
Unlike before, now my astra 777 only unlocks the
Before it's working fine, now my astra 777 only unlocks the driver door. What is causing the problem?
I need to no how to make relay to conect, the horn to the alarm
Posted on Mar 12, 2010
  • 63 Answers
May be a loose wire on the remote locking system, cheers
Posted on Dec 12, 2009
Hi, I have a Holden Astra TS city 98 model car and the remote on the key will open all the doors except the drivers door, so to lock all doors I have to put the key in the drivers door or use the remote &...
A plastic clip that holds the lock linkage is probably broke or worn. You need to pull of the inner door panel to see whats going on inside. Use the remote and see whats happening. It could be bent rod in door from someone using a slim jim to unlock it when they locked the keys in it at some point. Bend the rod and try the remote again untill it works properly.
Aug 31, 2014 | Cars & Trucks
Astra alarm worked fine, disconnected battery for 2 days now it arms but does not lock the doors?
Needs to be reprogrammed, system lost the match codes that go with the handheld. Two days was two days to long without power, system and the key fobs are not matched up.
Mar 15, 2014 | Scytek Electronics ASTRA7E7 Car Alarm -...
98 ford explorer Driver side power lock button doesn't work
The button may be defective. Unlike the other doors, if you have the electronic group there is a separate driver's door unlock relay which reverses the door lock motor, probably to disable the theft alarm and allow your fob to open just that door for entry. This relay could be defective. The master switch operates through door lock and door unlock relays and those relays could be defective also.
Sep 07, 2012 | Cars & Trucks
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
Sep 01, 2012 | 2003 Mitsubishi Galant
I have 2008 saturn astra, i can not open the door to the gas tank. Nothing in my manual. ?????? on what to do
The main reason this happens is because all the doors are not unlocked.
The fuel door does not have a release button, it relies on the door unlock button.
Press the door unlock button in the middle of the dash. (the button with a key on it)
This should release the fuel door and you can fill it up
Mar 02, 2011 | Air Conditioning and Heat for Saturn Astra
Drivers Door Lock Button Wont Unlock Car
Any of these three causes may apply to your situation of your driver's door not power unlocking, specifically the malfunctioning of the 1) relay system, 2) switch motor, or 3) the switch/button itself. Here's a handy diagnostic article that explains this:http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Locks_Power_Locks_Do_Not_Lock_When_Pressing_Locking_Switch_Button.htmThis should lead you to the correction of your door's failure to unlock.Brad
Jun 08, 2009 | 1994 Oldsmobile Cutlass Ciera
Scytek Electronics ASTRA777 Car Alarm 1 Cf 2way LCD Remote Logo
360 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
