Question about Acu-Rite Audio Players & Recorders
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Posted on Jun 23, 2011
AC system wiring diagram 2013 Chevy Spark
We have leamed that your 2013 model year Chevrolet Spark may have a condition where the air
conditioning (A/C) system does not work or cools intermittently due to inaccurate control of the
evaporator temperature sensor.
Your satisfaction with your Chevrolet Spark is very important to us, so we are announcing a program to
prevent this condition or, if it has occurred, to fix it.
Your General Motors dealer will inspect and, if necessary, replace the A/C compressor. Your dealer will
also, if necessary, replace the Evaporative Air Temperature (EAT) Sensor, install a low pressure switch
adaptor kit, and reprogram the Body Control Module. This service will be performed for you at no charge
until April 30, 2016. After that, any applicable warranty will apply
May 22, 2018 | AC Cars & Trucks
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
Feb 06, 2017 | Taylor Health & Beauty
Engine runs rough if it warms up won't start dtc codes p0118 and p0113 just did head gasket and replaced exhaust manifold all new gaskets new plugs wires and coolant engine timing marks are all c
P0113 Intake Air Temperature Circuit High Input
Low temperature results in a high signal voltage. When the PCM sees a signal voltage higher than 5 volts, it sets this P0113 check engine light code.
P0118 - The engine coolant temperature (ECT) sensor is a thermistor screwed into a coolant passage in the cylinder head. Sensor resistance is high when coolant temperature is low and resistance drops when coolant temperature increases. The powertrain control module (PCM) provides a 5 volt reference and a ground to the sensor. The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
Potential Symptoms
Symptoms of a P0118 could include:
  • A no start condition
  • Vehicle may start, but run very poorly, blowing black smoke, running very rough and misfiring
  • Illumination of MIL
Causes
A code P0118 may mean that one or more of the following has happened:
  • A bad connection at the sensor
  • An open in the ground circuit between the ECT sensor and the PCM
  • A short in the voltage feed between the sensor and the PCM
  • A bad PCM (less likely)
  • A bad temperature sensor (shorted internally)
Jan 04, 2013 | 2003 Dodge Stratus
P0128 (and P0116) on 2006 GMC Sierra v-8, 5.3L, 4x4. Originally getting low temp readings on guage. After replacing the thermostat, the problem seemed to be fixed. A few days later, I was getting my...
P0116 - Engine Coolant Temperature (ECT) Circuit Range/Performance Problem
The ECT (Engine coolant temperature) sensor is a thermistor which changes resistance based on temperature of the coolant in contact with it. The ECT sensor will be located in the block or coolant passage. Usually it is a two wire sensor. One wire is a 5 Volt supply from the PCM (Powertrain Control Module) to the ECT. The other is a ground to the ECT.
As the temperature of the coolant changes the resistance on the signal wire changes accordingly. The PCM monitors the reading and determines coolant temperature in order to perform essential engine fuel management. When engine coolant is low, sensor resistance is high. The PCM will see a high signal voltage (low temperature). When coolant is warm, the sensor's resistance is low and the PCM will see a high temperature. The PCM expects to see slow resistance changes on the ECT signal circuit. If it sees a quick change in voltage that isn't consistent with an engine warming up, this P0116 code will set. Or if it sees a lack of change in ECT signal, this code may set.
Symptoms: There may be no noticeable symptoms if the problem is very intermittent, however the following may occur:
MIL (Malfunction Indicator Lamp) illumination
Poor drivability
Black smoke at tailpipe
Poor fuel economy
May not idle
May exhibit stalling or misfires
Causes: Potential causes of the P0116 code include:
Missing or stuck-open thermostat
Bad ECT sensor
Short or open on signal wire
Short or open on ground wire
Poor connections in wiring
Possible Solutions: If there are any other ECT sensor codes, diagnose them first.
Using a scan tool, check the ECT reading. On a cold engine, it should match the IAT reading or should be equal to ambient (outside) temperature reading. If it does match the IAT or ambient temp, check the freeze frame data on your scan tool (if equipped). The saved data should tell you what the ECT reading was when the fault occurred.
a) If the saved info indicates that the engine coolant reading was at the coldest exreme (around -30 deg. F) then that's a good indication the ECT resistance was intermittently high (unless you live in Anchorage!) Check for an open in the ECT sensor ground and signal circuits and repair as necessary. If they appear okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
b) If the saved info indicates that the engine coolant reading was at the warmest exreme (around 250+ deg.F) then that's a good indication the ECT resistance was intermittently low. Check for a short to ground on the signal circuit and repair as necessary. If it appears okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
Other ECT sensor and circuit related DTCs: P0115, P0117, P0118, P0119, P0125, P0128
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
Symptoms: You will likely not notice any drivability problems other than the MIL illumination.
Causes: A code P0128 may mean that one or more of the following has happened:
Low engine coolant level
Leaking or stuck open thermostat
Faulty cooling fan (running too much)
Faulty coolant temperature (ECT) sensor
Faulty intake air temperature (IAT) sensor
Possible Solutions: Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
Verify coolant strength & level
Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
If the above items check out good, replace the thermostat
If Nissan vehicle, check for Technical Service Bulletins (TSBs), as the ECM may need to be reprogrammed to correct the P0128 code
These codes are telling you that the engine temperature is not sufficient. This can be caused by a faulty coolant sensor,air in the cooling system,or a faulty computer.
The engine should run at 190 F & higher when warmed up. Scan the computer system to view engine temperature.
Keep us updated.
Oct 01, 2011 | 2006 GMC Sierra
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
What does code: PO128 mean? I plugged it into the diagnostic machine, and that's the code that popped up.
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty coolant temperature (ECT) sensor
  • Faulty intake air temperature (IAT) sensor
The most common cause is a faulty thermostat. However here are some suggestions on troubleshooting and repairing:
  • Verify coolant strength & level
  • Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
  • Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
  • Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
  • If the above items check out good, replace the thermostat
Nov 20, 2009 | 2007 Chevrolet Silverado 2500HD
I have a code P0128, what is my problem is this in the cooling system?
This code is for your Coolant Thermostat - It's detected that the Coolant Temperature is below the Thermostat Regulating Temperature
This code may mean one or more of the following has occurred:
  • Cooling fan running too much
  • Faulty coolant temperature sensor (ECT)
  • Faulty intake air temperature sensor (IAT)
Check the following to see if it resolves your problem:
  • verify coolant strength and level
  • verify cooling fan operation and replace if necessary
  • verify ECT sensor operation and replace if necessary
  • verify IAT sensor operation and replace if necessary
  • if all above checks out, replace the thermostat
Oct 16, 2009 | 2002 Buick Rendezvous
Low collant light is on and has no leak and is full
This problem is common, if the coolant level is OK, check the "coolant sensor" and clean the plug.
Aug 28, 2009 | 1995 Buick Park Avenue
Dell 1450 Wireless Adapter ProblDell wireless
This driver works with 32-bit Vista and Windows 7
http://members.driverguide.com/driver/detail.php?driverid=1556056
Aug 21, 2009 | Dell 1450 (D1450U) Wireless Adapter
326 people viewed this question
Top Acu-Rite Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Acu-Rite Audio Player and Recorder Expert? Answer questions, earn points and help others
