Question about KitchenAid KEMC377K Convection / Microwave Oven
I have a KitchenAid Microwave that the tension spring is broke. I need to order a replacement part. The model is KAW38AVM726. I have seen the same model number on your website, but it seems the model number is changed as I can not find it on most websites for parts. Also need diagram if possible.
  • KitchenAid Master
  • 9,098 Answers
That model number does not look right. Please check the tag on or in the unit again.
You can find helpful exploded view diagrams and order parts here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you should be able to download it here.
The door springs must be replaced in pairs to keep the wear even.
Posted on Dec 13, 2009
Kitchen aid kemms308sss04 plastic insert on turn table broke how do you replaace
That may be called the turntable coupler or turntable support or roller ring assembly.
You can find helpful exploded views and part numbers at the link below, by replacing XXX with the full model number found on the tag on your microwave (not on the service manual).
XXX&siteCd=WHRCOM&userType=Consumer">http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
My preferred place to order Whirlpool parts is from the Pro here.
Feb 16, 2014 | KitchenAid Microwave Convection Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
When i open the door it felt like a spring broke. i have to hold the door from slamming open now
That would be a broken door spring, and it's best to replace them in pairs.
On some models, this can be a difficult job.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Good luck.
May 25, 2010 | KitchenAid Microwave Ovens
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Microwave door comes down hard and fast. Lost it's tension/spring? Also liquid has gotten in between the door of both the Microwave and oven door. How to clean?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Oct 11, 2009 | KitchenAid Microwave Ovens
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 24, 2008 | KitchenAid KHMS147HS Microwave Oven
Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
Dec 16, 2008 | KitchenAid KEMC377K Convection / Microwave...
Need to remove kitchenaid microwave model kemc308ksso door to replace spring
Aug 19, 2008 | KitchenAid Microwave Ovens
Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
Jun 09, 2008 | KitchenAid KHMS155L Microwave Oven
KitchenAid KEMC377K Convection / Microwave Oven Logo
352 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
