Question about Pride New Mobility Legend 4 Wheel Scooter
How do i remove the pride legend classic xl8 seat
  • Anonymous Mar 22, 2014
  • Anonymous Mar 24, 2014
    My horn does not work and is there a reversing bleep/horn. I have been advised there could be a fuse underneath the speed meater reading. Will this have to be taken appart to replace the fuse?
    Regards
    Derek Harris
  • Pride Master
  • 1,367 Answers
Hi, be careful here as it can make your back ache,
now there is a lever to the right of the seat, pull it up towards you and
turn your seat 90 anticlockwise, so the seats not facing the control panel, at right angles, you should now be able to lift the seat , take great care here if you have back problems in the past as some seats are quite heavy.
Regards
GeWiz.
Posted on Dec 13, 2009
Testimonial: "thanks"
SOURCE:
Legend classic x18 measurements
hi, can you explain in more detail what information you require ?
The XL8 is one of the best 8mph mobility scooters out there, sadly it been replaced by the Pride colt brand..
Regards
Jan 21, 2013 | Pride New Mobility Legend 4 Wheel Scooter
The right hand side indicator does not work on my Pride Legend Classic XL8. I have checked the fuses and they are ok. The left hand side indicator and the hazard flashers work perfectly. Please help.
Hi if when you put the hazzard lights on all the indicators work then this suggests the problem is with the indicator switch, you may need to get it replaced, it could be that it has got corroded due to rain or damp getting in, if the hazzords are working ok then you know the fuse and bulbs are good so all thats left that could be wrong is the switch that works the indicators.
this will need removing and replacing to solve your problem
Aug 18, 2010 | Pride Mobility Products Pride Legend XL -...
How do you raise the seat on a pride legend XL8 mobility scooter
Hi...
There is a shaft pin under the seat
Pull the arms off ( temporarily)
Lift the seat slightly, remove the pin,lift to where you want it and put pin back in the hole
If this helps , please rate my help
Apr 05, 2010 | Pride Health & Beauty
I have a pride legend classic xl8 and the spline drive from the motor to the diff has snapped, where can i get a new one or do i have to get a new rear axle complete?
hi, can you send me a picture of this so I can assess the damage, I have repaired many gearboxes so it not a problem.
helpNOSPAM@gewizrepairs.co.uk
just remove the NOSPAM from the emaill adress so it correct.
Regards
GeWiz.
Dec 10, 2009 | Pride New Mobility Legend 4 Wheel Scooter
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Oct 19, 2009 | Pride Mobility Products Pride Legend XL -...
I have mislaid my Legend Classic XL8 manual & wish to know all the flash error codes
This page has a link to the users manual near the bottom:
http://www.cheapest-scooters.co.uk/8mph/pride-legend-classic-xl8-mobility-scooter.html
Aug 21, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Pride New Mobility Legend 4 Wheel Scooter Logo
928 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
