Question about Lavazza Espresso Point Capsule Machine
Lavazza espresso point machine will not pump water out of tank tru machine
  • 74 Answers
SOURCE: Saeco Gran Crema Espresso does not pump water
The machine needs to be primes.
Please trie and release hot water though the steam nossle.
Do like this
Open the steamer and then trie and make a cup of coffe. this will make the hot water come out thought the steamer instead of the coffe outlet.
Why you should do this is becuse the machine has it alot more easier to prime it self though the steamer then the coffe outlet.
Posted on Jul 11, 2008
z34aga
  • 137 Answers
SOURCE: priming pump
Yes both tubes goes to water tank. One drains water from tank to pump, the other is getting back clear water when pressure is very high from security valve.
Posted on Mar 28, 2009
SOURCE: LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
Help
Posted on Sep 29, 2009
SOURCE: I just got a used
You will need to replace the pump. Contact www.lavazzarepair.com to obtain the replacement part you would need or create a buyer dispute with Paypal if the ebay seller won't give you a full refund.
Here is the contact number and email to order a new pump:
1-917 847 1146
rmontan194@aol.com
Posted on Dec 07, 2010
SOURCE: Lavazza Espresso Point Fuse Location
Lavazza Point Espresso machine fuse location.
On the exterior rear of the espresso machine, where the electrical plug connects to the unit there is a small 250v fusible link receptacle behind a plastic cover lid directly to the left of the plug terminal. Disconnect the plug (it is a female connection that can easily pull out) Gently pry open the fuse compartment and remove the two fuses for inspection. The fuse lid door does not open completely. Beware not to damage the lid door by using excessive force. If fuse link is separated, replace it with a new 250v fuse. such item can be found at any hardware store or local radio shack .... H2o4nyc
Posted on Oct 17, 2011
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
The machine is filled up with water , but the water line level keeps blinking kie it's empty
Check the Float Rocker inside the water tank. Sometimes this comes off the retainer when filling the tank. If this is an older machine from early 2000's or 90's the tanks will have different type of sensors. Most of them that are older the sensors are normally broken and need replacements.
Apr 21, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza point espresso machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Jul 23, 2008 | Lavazza Espresso Point Capsule Machine
Need a manual for espresso point machine
A good descaling might help. How is your creama, is there still a good amount being produced? Does the coffee taste burned? there might be something impeding the pump or flowmeter, maybe even the three way valve. should you want service you can call 781-393-2929. we are an authorized lavazza distributor and service center.
Apr 07, 2008 | Lavazza Espresso Point Capsule Machine
Did you fill it with water? are any of the lights blinking?
Jan 02, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
510 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
