Question about Sony Playstation 3 (PS3) Console
I keep getting kicked off line when my phone rings. I am using a wireless modem from verizon which has a router built in.
  • pjlyn Dec 12, 2009
    no, dsl via verizon
  • Brandon
    Brandon May 11, 2010
    Are you using dial-up?
  • 115 Answers
Well, I would definintally contact Verizon for this issue since it might be a problem at their end. There phone number varies according to your location so you can use any of these ways to contact them here.
If your not very network savy I would not touch your router just yet.
If I helped, please help me by rating me.
Good luck,
Brandonmxb
Posted on Dec 12, 2009
  • 44 Answers
Change the adsl filter
  • shageexx Dec 12, 2009
    You could try restoring the router,if you know the settings,or then ring verizon :)
I have a Dell 966 AIO printer. All of the functions of the printer are working correctly, however, many of the phones in my home have ceased ringing. All are live and calls can be placed and received,...
Setup should look like...
Wall > ISP Modem/Router > Wireless router(if any) > Wired/wireless
If using DSL, a DSL Filter MUST be on ALL devices, phone, answering machine, faxes, etc..., everything EXCEPT the DSL Modem/Router.
You may share a DSL Filter.
Wall > DSL Filter > Splitter > Multiple Devices
RFick
Jun 11, 2011 | Dell 966 All-In-One InkJet Printer
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Kick out of the line during internet surfing
verify AT&T if your modem have built in router, if does disable the DHCP server from second router, if you are using wireless, change the channel to 8 instead of 6, maybe you have neighbors using the same channel.
Mar 25, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Wireless connectivity with Vista
since you have verizon modem wireles router..
i have the same issue with the same model...I call verizon and tell the issue...verizon accepted that modem router have problem in wireless...i know that all my computers have no issues because i maintain and built those computer by me..
then Verizon send a new and different modem router...this time it works fine...since i received it last week. call Verizon regarding the wireless issues ..tell them too that you have some dead spot on your wireless..like if you move away more than 15 feet..your wireless connection get lost..
i hope this might help
Mar 16, 2009 | HP Computers & Internet
My internet keeps dropping out
possible reasons:
Dial up:
  • phone line problem.especially in wet weather,crackling on the line ,call the telco.
  • modem\router on its way out. connect directly to the modem and try it .
  • settings for idle time before disconect needs turning off, (set to 20 minute by default)in most cases.
  • if you have call waiting ,turn it off ,as it can kick you of the net when a call is trying to comes in.
if you use ADSL and/or wireless :
  • some of the above and
  • some USB dongle are prone to drop out,
  • try using a Lan cable
  • brick walls and other hard surfaces can interfere with the signal if you are away some distance from the wireless router.
  • cordless phones can cause problems, keep them away from the modem\wireless router and wireless dongle, or adapter in the pc/laptop
good luck with this and let me know how it goes
Terry
Apr 02, 2008 | Computers & Internet
Westell 327 wireless router
you have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
Mar 29, 2008 | Westell Wirespeed VersaLink...
Wireless connection
Has any machine ever successfully connected through your router to the internet wired or wireless?
If not the requirements of your ISP must be reviewed to assure the wan/modem side of your router is configured correctly. This will require at least your ISP (phone./cable company) name or preferably a link to his support web site to gather information.
The manufacturer's and model of your wireless router/access point and wireless adapters (computer if the wireless adapter is built-in) will also be required to acquire common copies of the manuals to facilitate the configuration of the devices.
IF you provide the necessary information in a comment to this problem we can continue to step toward the establishment of a wireless connectin to your laptop.
Dec 20, 2007 | Linksys Wireless-G WRT54GS Router...
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
