Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My oven was accidentally locked while the door was opened and I do not know how to unlock it. I do not have an owners manual. I got the stove second hand. how do I unlock it so I can use my oven?
    Problem Solver:
  • 5 Answers
I unplugged the stove. Checked to make sure my motor fuse was still good and plugged in. I am not an electrician but I can read. Plugged it back up, and all was well.
Posted on Dec 13, 2009
I have double wall unit Thermador oven. After self cleaning, the door can not open. Or may be I hit the panel lock , so the door is lock. How to unlock?
Hello April,
If any OVEN FUNTION is being used...
The controls cannot be LOCKED off...
So no... REQUIRES PUSHING 2 buttons & holding
for four (4) seconds... (not likely to be accidental)
The steps to Lock & Unlock are the same...
(see reference page (click here)
Thermador SCD302 Care And Use Manual Child Lockout
Touch and hold the COOK TIME pad and
the STOP TIME pad simultaneously for 4
seconds.
Likewise SELF CLEANING is described in great detail.
(double click this URL)...
Thermador SCD302 Care And Use Manual Page 29
ELSE...
Please contact THEM if you have questions or comments.
Phone: 1-800-735-4328 or reach THEM through their
website at www.thermador.com
Hope this helps
Carnac the Magnificent
Dec 20, 2017 | Thermador Ovens
Oven door will not open after self clean
There are two easy things to try to fix this.
First, unplug the oven, or turn off the circuit breaker to it - so long as power is cut to the oven. Leave it for about 5 minutes, then plug it back in or turn the circuit breaker back on and try to open the door.
If that doesn't work, turn on the self-cleaning cycle again, and let it run for about 15 minutes. Then turn it off and wait another 15 minutes, and see if the door will open.
If neither of those work, you have a more serious problem with the locking mechanism. Either a bad solenoid or a damaged heat locking mechanism. Both of these will require removing the stove top to access and repair. Let me know if the above suggestions fix the problem. If they don't, I will get you more specifics on repairing the locking mechanism - assuming you're up for that.
-Dyllan
Mar 06, 2008 | Ovens
Oven door won't close
if you look around under the handle or under the top of the stove on the front there should be thin lever. This lever is designed to lock the oven door closed tightly when you are activating the self cleaning oven feature. It is likely that someone accidentally lock the lever while the door to the oven was open. Simply find that locking lever return it to the unlocked position and your door should shut fine.
Dec 26, 2013 | Ovens
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
My stove won't unlock
there may be a problem with the door switch try pushing in the door a little bit.also hold the clear off key for 3 to 5 seconds this should allow you to open the door.
Jan 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Series Oven Locked
Not familiar with this particular stove, but it sounds like you activated a child protection lock. To turn these on and off, you have to hit that lock icon and hold it for 4-8 seconds for anything to happen. This is so that the kids won't have sense enough to unlock it, assuming that you locked it to keep them out!
Also, frequently they work  in stages. Hitting it one time (for 4-8 seconds) will lock the panel, hitting it another time will unlock it, hitting it a third time might lock the door, and so on. So RTFM, or just keeping hitting it multiple times for 4-8 seconds each, and see what does what. But the manual should tell you everything you need to know. You can go to the GE website, or to managemyhome.com, which is maintained by Sears, and you should be able to find a PDF copy of the manual if you don't have the manual that came with it.
Feb 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
187 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
