Question about Bosch Garden
My mini mix cement mixer is broke the drum wont when loaded
I have an old mini mix 150 belle electric cement mixer.Which has just stopped workingYou had to push the drum to get it turning. now when it is loaded it still turns manually but wont turn on its own .You can push the drum around by hand but it wont turn on its own.It does turn electricaly when its empty...Any help please would be appreciated.
The motor is ip45.
I cant find the right section for this
4 Suggested Answers
  • 314 Answers
SOURCE: Chainsaw electric motor jammed
Remove the chain, then see if it will turn over by hand. Does it have a chain-brake??? Frankster016
Posted on Oct 21, 2008
SOURCE: I need wiring diagram for
Small BLUE at top right hand corner, then the two rows of two...
top left is BLACK, top right is GREY, bottom left is BLUE from the power supply and bottom right is a short BROWN wire with a spur, which leaves a BLUE to connect to the spur. should be it :)
Posted on Oct 21, 2010
  • 1015 Answers
SOURCE: Hello, We have a mini
I would find out if it is belt or direct drive. Either way check to see if it put gears out of alignment or idler pulley so that belt can not engage.It may have jarred the motor so that it needs repositioned. At least with the motor runningit sounds to me like you just moved or bent something out of position and it won't be too hard to repair. Good luck and thank you.
Posted on Jun 25, 2011
I lost the directions for my cement mixer. how can I get a copy of it?
what directions do you require
how to mix cement ( on the bags)
how to service the motor if petrol ( google manufacturer of the engine and down load pdf version for the engine
Jul 03, 2017 | Masonry Tools
Why does my Hobart 30 quart mixer cut off after 15-30 seconds of mixing?
The small button that pops out is your over load protection for the electrical motor
There might be a phase missing from your power supply.
The motor might have a problem.
Or the gearbox is faulty and couses the motor to struggle to turn and thst is the reasons for a over load protection to trip
Jul 26, 2015 | Food Mixers
A belle cement mixer,wont stay on when start button is pushed,changed switch ,still the same?
Sometimes the most simplest of fixes is verifying that you have voltage at your outlet and that you have voltage getting to the motor.
Check the motor's overload button; reset if necessary.
Take resistance readings:
  • start capacitor
  • run capacitor
  • and motor
If anyone of their specs are out of whack, that's the component that is defective and will need to be replaced.
Mar 24, 2015 | Masonry Tools
When mixing pizza dough in hobart se 601 mixer the dough hook stops under load any suggestion
Depending on how old the mixer is, I would check the belts (if it is belt driven) to the planetary gears. If it is not belt driven, it sounds as if the motor is faulting out. I would replace the motor brushes first before spending money for a new motor. This may not be an intelligent question but I have to ask, are you overloading the mixer? A 12 quart mixer will do fine with cake batter but when you mix pizza or bagel dough, the moisture content is much less and it is equivalent to cement. Sorry, I had to ask because I have seen this before. Good luck and I hope this helps.
Oct 20, 2014 | Hobart Mixer Only, Planetary, Bench, 12...
MY MINI MIX CEMENT MIXER IS BROKE DRUM WILL NOT TURN WHEN LOADED
This is the food mixer forum, not much cement gets mixed in the kitchen around here, too much danger of a flying rolling pin.
Sep 06, 2014 | Food Mixers
The wires have come out of the switch
take it to an electronic repair shop in town karen don't fix yourself!
Mar 22, 2014 | Bell Labs Protecta Load-N-Lock Anchoring...
Lescha Hobby 125 S electric mixer requires new drum main bearing
I had a similar problem on a Lescha Hobby Mix 120 SF. (Sounds similar to yours) The failure seems to have been caused by corrosion of the ball bearings. If you get water into the rear bearing housing when it is operating, and then store the mixer with the opening in the drum downwards, the water collects around one of the bearings. The bearings are a standard size ball bearing with a 62mm outside dia, 30mm bore and 16mm wide. I bought the sealed version from a local bearing supplier (or look one up on the Internet). The original ones fitted are unsealed, which is part of the problem. I also bought two new bearing retaining external circlips for a 30mm shaft. I had a paint round inside the housing with hammerite, and drilled some 10mm dia drain holes around the outside of the housing near the bolting flange. I also store the mixer with the drum horizontal now.
May 27, 2011 | Gazillion Cement Mixer
Iv'e got a belle cement mixer 150, i think the motor is on its way out, its around a 2007 model can you tell me if you can put new brushes in the motor if so how, or if i can have the motor reconditioned ?...
i have a belle 110v cement mixer just over a year old.Everytime i use it ,it switches itself off after mixing 2 barrows of concrete but it will run perfectly for hours when empty.(tryed this out on Monday)So therefore it only switches itself off when loaded.
Gets very hot quickly.
Any suggestions would be much appeciated.Brian
May 03, 2010 | Home Fencing
Garden Logo
1,782 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
