Question about Marantz DR-4050 2-Disc CD Recorder
CD door not opening.
I am trying to find someone who can repair my Marantz twin deck CD recorder. The recording side of it, apparently needs a new micro switch so that it can be opened by the remote controller. There is no manual way of opening it. The shop that sold it to me has long gone and I can find no-one who can do it. Thanks
Julia
  • LadySoul Jan 22, 2008
    My Phillips cd recorder does not open with remote or manually, any suggestion I just purchased used from a e-bayer
  • 112 Answers
Usually failure to open means a faulty motor - when you press eject ca you hear the motor spinning or is it quiet? If in the UK contact me via ebay - fluffcat1 - and I can help further.
Posted on Jan 22, 2008
Marantz CDR510 Display is blank
If that is the case there is a missing B+ line to the display, you will need a circuit diagram to find the fault.
Mar 13, 2012 | Marantz CDR510 2-Disc CD Recorder
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
Philips 765 CDR - twin deck
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Jun 03, 2009 | Philips CDR600 CD Recorder
Marantz 300 C.D recorder no signal/tons of static on recording
your set is damage due to static there are lots of tech in your area look into fixya directory and you will find a tech close you.i recommend that you purchase a new set to repair it will be costly. good luck.
Apr 10, 2009 | Marantz CDR-300 CD Recorder
The optics are most likely defective. Yes you will need to replace the optics assembly. I don't have a location for parts outside of the US, but you should be able to locate a parts distributor for Marantz in Europe.
Dan
May 29, 2008 | Marantz DR-4050 2-Disc CD Recorder
Marantz DR-4050 2-Disc CD Recorder Logo
276 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
