Question about Remington Polesaw Wizard
Locking devise on pole extention. Made of plastic and allows the pole to be locked at the correct laenght. 352 787 5245 John lambert Lambert9231@comcast.net
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: where can I find a replacement locking nut for the
Without the model number, I can't provide you with the part. However, you can go to masterparts.net and click on the Remington chain saw link and with your model number, get a line drawing and list of all available repair parts and pricing.
They have almost all the parts for even most discontinued Remington chain and pole saws and have a toll free number you can call, once you have your model number to provide them with. 1-866-672-6040
Hope this helps and best regards!
Posted on Jul 31, 2009
dontbother10
  • 2220 Answers
SOURCE: The plastic Pole Lock (Thumb Latch)on my Remington
RemingtonPower is no longer in production, The "Coupling Nut" was replaced by a "Thumb Latch" neither of these nor the entire pole assembly are available.
You might try this (no promises).
http://store.poolcenter.com/shared/StoreFront/product_detail.asp?RowID=167966&CS=poolcenter&All
Someone recommended using a hose clamp in place of the nut.
I think these are band-aids and eventually you will need a part that cannot be found.
We rarely get inquiries for McCulloch or Poulan electric units. Might be worth a look.
If you care to try on your own start here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Sometimes you can find NLA parts (use part number for above) offered here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
If you have more questions or need additional help please reply below and I will get back to you. and Good Luck. HTH
Lou
Thank you for using FixYa.
Posted on Apr 18, 2010
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
Why does the water filter in Whirlpool Gold refrigerator make a loud noise when I depress the water?
Remove the filter and reinsert with force..
Whirlpool Fridges have many styles, the more common
one to make noise is the style with the filter inside the
fresh food compartment hanging from the ceiling. This
is the Amana Bottom Freezer. If I'm correct: remove the
the filter and apply a thin film of vegetable oil on the rim
of the filter locking collar. This may allow the filter to turn
abit more, enabling water to flow faster..
There are 2 light blue pins the locking collar must push in
when turned. If this does not remedy replace the filter head
assembly.(Part the filter attaches to)
John Wright
Jul 27, 2014 | Whirlpool Refrigerators
How do you attach the chainsaw to the pole?
You simply mount the saw between the two metal plates.
There are two screws holding the plates together.
Look in the owners manual and it will guide you how to attach the saw.
Once the saw is attached, plug in the power cable that is on the end of the pole. One word of advice....there is a large locking collar ring that enables the two poles to extend and lock together. There has been numerous reports that the locking collar ring splits due to overexersion. You can add a stainless worm clamp (similar to a radiator hose clamp) around the rind and tighten it securely. Be sure it is a heavy duty wide clamp. This will help to keep the ring from splitting under pressure.
Jun 25, 2014 | Remington Electric Pole Saw
You must close the door hard or it will not start
The locking mechanism is not closing completely unless you slam the door because the plastic parts don't slide easily after a couple of years. We found that putting a small amount of vegetable oil on the 2 locking hooks in the door will allow the components to slide easily and close properly so the machine will function correctly.
Mar 02, 2014 | Panasonic Microwave Ovens
What is the Stop Lock locking system?
The stop lock locking system does not adjust pole length, but rather prevents pole sections from completely disengaging.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
Uppa baby vista won't lock into place when open
This is what will work. First get some WD-40 and spray it around the jammed locking pin. Give the lubricant 10 mins and then get a knife or flat head screwdriver. What you will want to do is try to pry the locking pin up. Be gentle as you are dealing with plastic and if you break the plastic locking pin your stroller is done. As you slowly pry the pin upwards you will feel or see grooves which you can use to continue to raise the locking pin. Once the locking pin is unjammed push down on it a few times to get dust,dirt or sand out of the locking pin. The pin should pop up freely every time you push down on it and let go.
Hope that helps as I also had the same issue.
Aug 25, 2012 | Vista UPPAbaby - Carlin Stroller
2006 hyundai diesel crdi outomatic will not engage in drive from cold start. reverse no problem. after engine has been idling for some time, drive will engage.
Hi Daniel, I believe that your problem may be connected to the safety locking devise which will not allow the lever to shift until the brake is pressed and the button pushed in. It may be a bad contact. Regards John
Apr 29, 2012 | Cars & Trucks
Hood wont catch on the main latch on my 1998 montana
Hi JM, The catches do wear out and more likely the cables become frayed and do not allow the hood catch to return to the correct position for locking. Try pushing in the handle inside the car. If it work then have the cable replaced asap. If not , you may need to replace the catch mechanism Regards John
Feb 12, 2012 | Pontiac Cars & Trucks
I need a replacement lock on the pole of a remington 106890-02 pole saw.
Remington has closed its door. Bankrupt. If it has the round locking plastic nut, go to a swimming pool supply house.Same mechanism used of pool cleaning extension pole
Nov 19, 2009 | Remington Polesaw Wizard
Need locking latch for Remington Electric Chain saw
You've got the one version of the Remington Pole Chain saws that doesn't have a separate parts breakdown online.
However, here's a owners manual for your pole saw and a parts breakdown that can be used for most replacement parts, as the RPS-96 is a similar version of your model.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_OM.pdf
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
You might want to contact the factory to verify that the parts are the right ones before ordering them by calling 1-866-672-6040
Hope you find this very helpful and best regards!
Aug 07, 2009 | Garden
Remington Polesaw Wizard Logo
81 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
