Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Frezer defroster runs to long
Freezer defroster runs to long
    President:
  • 1,218 Answers
Good day,
If the machine has a mechanical timer, it is in the fresh food compartment behind the top front panel.
Normal defrost cycle is approx. 21 minutes.
If it has an adaptive(solid state) timer it is located in the same area, and on most models can be replaced with the mechanical model.
Posted on Dec 12, 2009
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
My refrigerator is not getting cold frezer work fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | Refrigerators
Freezer is not defrosting. it's a RF265ABPN model
Your defrost termination sensor has failed & needs to be replaced.(very very common problem with todays fridge's specially samsung)
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
Frezer is cold refrigerator is warm
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 09, 2010 | Haier HTE18WAA Top Freezer Refrigerator
The fridge is not cold, but the freezer is and the fan fan is still on in the frezer.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101..
Oct 15, 2010 | Frigidaire Refrigerators
Frezer keeps frezzing
If the freezer is icing up your defrost timer or the heating element may be bad. If the fridge doesnt go into defrost mode you will get frost on the back of th freezer and ice will freeze up on the coils eventually it will not cool the fridge side very well at all. If there is an ice block let me know also is the fan in the freezer running?
Aug 15, 2010 | GE Refrigerators
The freezer works but the refigerator section does not. When you turn the temp switch for the refrigerator it will turn off the freezer also.
dont tuch the thermostat put it in normal setting!
now, check if your fan in the frezer working, if it is working che3ck the thermostat unit and heater in the frezer unit also need to see if the frosting is eaven all over in the frezer side..
contact me at www.911servicetoday.com
Dec 30, 2009 | Refrigerators
After clean, the magic chef chest frezer no linger frezen.
I think in the defrosting process, the evaporator was damaged causing refrigerant leakage. sorry... dont try to repair.. it sucks in moisture
Aug 26, 2009 | Freezers
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
