Question about Samsung (TN-RBNG10) TV Input
My Samsung TV has no USB input. I want to connect a memory stick with foto or video material. Is it possible to connect with a connector (USB to coax) to the standard TV coax input and show pictures of movies on the TV?
  • 2,360 Answers
There are devices that can read SD,Micro SD with RCA jack (YELLOW JACK) that made for TV viewing. Digital picture frame with yellow RCA out out + converter to coax plus. ==== Example eBay Item number:230382583829 SD Card + USB Media Player for TV - Connect to your TV if your are using MicroSD then you will need a MicroSD to SD adapter. It's real cheap. should do the job for you. LINK HERE === Please rate my answer if it's useful to you. Cheers, MUSTGO
Posted on Dec 12, 2009
SOURCE:
Hitachi 50hyt62u H can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store.
You can connect a USB hard disk drive or USB
memory stick to your TV by using the USB inputs of
the TV. This feature allows you to play files stored in
a USB drive. 2.5" and 3.5" inch (hdd with external
power supply) external hard disk drives are supported.
IMPORTANT! You should back up your files before
making any connections to the TV set in order to
avoid any possible data loss. Manufacturer will not
be responsible for any file damage or data loss. It is
possible that certain types of USB devices (e.g. MP3
Players) or USB hard disk drives/memory sticks may
not be compatible with this TV.
Quickly plugging and unplugging USB devices, is a
very hazardous operation. Do not repeatedly quickly
plug and unplug the drive. This may cause physical
damage to the USB player and USB device itself. Do
not pull out USB module while playing a file.
Media Browser Menu
You can play photo, music, and movie files stored
on a USB disk by connecting it to your TV and using
the Media Browser screen. To do this, perform the
following: Connect a USB disk to one of the USB
inputs located on the side of the TV.
You can connect two USB devices to your TV. If both
USB devices include music, picture or video files, USB
selection OSD will be displayed on the screen. The
first USB device connected to the TV will be named
as USB Drive1. Select a device by using up or down arrows
and press OK
Nov 23, 2017 | Hitachi Computers & Internet
I have a 50 inch Samsung Plasma Display TV PS50Q91HDX/XSA. I would like to know if a USB memory stick will work on this TV to watch movies. Thank you.
If you have a usb input and the set has the correct codecs built in, you will be able to watch a movie. May not work with all files. The usb input on a dvd blue ray will usually work with everything however.
Jun 26, 2016 | Samsung Televison & Video
How can I watch my digital photos on the TV? Where do i have to go to on the menu?THX
If you connected via USB you'll have to change your TV's input to the USB port where you have a flash stick or hard drive connect. Normally this would be done by pressing the SOURCE or INPUT button on your remote. Since I don't know what your TV is that is the best answer I can give you. With most modern smart tv's you can also sync your TV to your phone either by WiFi or Bluetooth. In this case you might need to enable, turn on, that feature in your TV's system Menu.
I hope that helps...
Mar 03, 2015 | Televison & Video
How do I transfer my photos from my camera to tv
If your TV has ab USB port then you can copy the photos from your camera to your computer and the copy the photos from the computer to a USB flash memory stick.
Then insert this memory stick into the USB port on the TV and select the USB input to display your photos.
May 28, 2011 | Computers & Internet
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
Hi is there usb connection and pc input so that we can see movies in 330ld
The usb on the back of samsung tv's is for updates only - you download firmware updates from samsung support and save them to a memory stick. Put the memory stick in the usb port on the tv and start the update mode.
The pc input is for connecting things like laptops and older progressive scan dvd players.
Hope this helps.
Jan 19, 2011 | LG 32LG30 32 in. LCD HDTV
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Jan 11, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
My Sharp Flat Screen Tv Model LC32SB24U has a USB input recepticle in the back. I bought a usb cable connected it to my computer and nothing happens? what is it used for. My tV came with NO disc for...
The USB entry is mostly used for a foto slide show.
Please read the owners manual before plugging in any kind of USB sticks or other cable's in a TV set.
It can damage the set when there is a ground connection between some devices.
Nov 12, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Memory stick duo
Well your memory stick can be used for many things, however its main feature is to save data, you can save the progress of any game. You can also save your fotos, videos, music, themes for your psp, and wallpaper.
To save files from your computer simpli connect your psp via usb and under settings select usb connection... your computer should detect your psp automatically and you will be able to save your files on the corresponding folder
Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
My hd tv
to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
64 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
