Replacement Cost Information For Damaged Washer & Dryer
Hi!
We recently moved & our washing machine & dryer were damaged in the move. The moving company needs the PURCHASE price & suggested REPLACEMENT costs for them.
I have searched for info. & none found on the internet. Also, the information is unkown at Kenmore since they are out-dated.
Do you have any suggestions as to how I can find out this information?
Thanks!
JM
    President:
  • 1,314 Answers
If they were kenmore then more than likely they were built by whirlpool look at whirlpool for copariable models by going to lowes .com you can find same looking models but with the whirlpool name
Posted on Jan 20, 2008
FRIGIDARE DRYER WONT START
Hi elclarkjr - First, have you recently clean the lint screen/filter? Also check that the power cord is not damaged. Otherwise the dryer may possibly be experiencing more serious issues like; a wiring failure, faulty control board, thermal limiter, or defective door switch that only a professional can repair. I personally recommend consulting a service provider for a proper diagnosis and to move forward accurately.
Feb 23, 2013 | Frigidaire ATF6000ES Front Load Washer
We moved our Kenmore stacked washer/dryer from downstairs to upstairs - now it will not work. any ideas?
If the dryer didn't get banged around or damaged when you moved it, it sounds like it might be a power issue. Is the outlet where the dryer plugged into controlled by a switch? If so, make sure the switch is on. Is it on an electrical circuit with any other large devices (air conditioning unit, refrigerator, etc.)? If so, the dryer probably isn't getting enough power. Try plugging it in somewhere else, on a different circuit (using an extension cord to test it, if you don't want to move it until you're sure) to see if that makes a difference.
Jan 15, 2011 | Kenmore 98702 Stacked Washer/Dryer
WE HAVE JUST RELOCATED OUR WASHER AND DRYER FROM THE GARAGE TO A ROOM IN THE HOUSE. THE WASHER WHEN FIRST STARTED CAME UP WITH ERROR F/H. I WENT BACK AND CLEARED LINES AND MADE SURE WATER WAS COMING INTO...
take back pannel,off,,,,,,,,,when disconected from mains,,only,,
see if belts on
if so
did you manualy move, did you keep uprightif not the suspesion damaged??
or ??? lots off damage when move incorrectly..
without transit brakets,,
Jun 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking out of the washer when it is filled up
if it leaks only when full, not moving, may be crack in drum, specialy if plastic. if leaking while running, could be a loose hose clamp or damaged hose. also make sure you are not using to much soap, in compact units it will bubble over the drum
Aug 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Once dryer starts the gas will burn for a while then go out and does not restart. if you stop the dryer and let it set for a while it will restart and dry the clothes. also if the gas is not on the timer...
HI, this is a defective timer control module. replacing this failed component will fix this issue. the timer is responsible for initiating the heating cycle. If the timer motor mech is damaged and not moving, it will not dry properly. replacing the timer will fix this issue you are having at this time.
Jun 16, 2009 | Washing Machines
Noisy dryer
i had same problem with washing machine. i found out it was the stone inside which holds it down while it spins. The screws or nuts or what ever is holding the stone could be loose.
Or it could be the nuts or screws of the actual drum that spins that got loose when you moved the machine
Nov 10, 2007 | Washing Machines
Runs through the whole programme washing and drying mixed in about 5 minutes
can be fixed but it will more then likely be the timer and this can cost upto £160 to have someone to come out to do it so replace it u could buy a graded washer which is just a pre-damaged waher ie;dent or scratch this will save u around £150 on new this is the best information i can offer to u m8
Oct 15, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
