Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
Hello all features seem to work except hearing me talk when placing or receiving calls the user on the other end does not hear me but i can hear them
Why can't they hear me talk on a call
You phoned microphone needs to be replaced. The speaker and Mic are two different components and works independently as well. IF people on the receiving end cant hear you, then your microphone is not fuctioning. Take it ti yiur dealer if it is still under warrantee or a reputable repair shop to replace the microphone
Aug 11, 2014 | BlackBerry Z30
TalkAbout MR350 not hear Talk About MD200
Check your CODE settings. From your description you likely have the CODE set to a different number on the MR350 than the MD200. I would guess the MD200 is set to zero since you can hear the MR350 when it transmits. Set your codes to match one another, and turn off any special features such as call alert or Qt filtering.
Ordinarily I would post links to the user guides, but FixYa seems to be having a problem with this feature today. If you need the user guides visit giantintl dot com website.
Best regards.
May 22, 2013 | Motorola MR350 Two Way Radio
My headset is working except for be able to hear me speak
There are no mute buttons for your bluetooth headset, your microphone must be blown off, try contacting service personnel, you will get it fixed.
May 24, 2010 | Motorola Mobility H700 Wireless Headset
The main speaker (receptor) do not work
The problem why you cannot hear the person you are talking to with the one at the top front(the main earpiece) is that the front earpiece of your phone is bad that is you cannot hear anything unless you put it on speaker.
All you need to do is to replace the front earpiece of your phone and you will see that you will hear when you are talking to anyone.
Change the front earpiece as advice and you see that you will hear your conversation when calling or receiving calls.
Take care.
May 09, 2010 | HTC Touch HD Smartphone
I cannot hear anything on MY end when I make a call or receive a call and the volume is completely up. It is not on mute and the person on the other end of the call can hear
The problem with your phone is that the earpiece of your phone is faulty that is why you cannot hear anything when someone calls you or when you call someone.
All you need to do is to change the earpiece of your phone in other for people to hear you when you make calls or when you receive calls.
The earpiece of your phone is bad that is why you cannot hear anything when you make calls, change the earpiece of your phone as advice and you will see that you will hear when people call you.
Take care.
May 02, 2010 | Samsung SGH-L700 Cell Phone
Problem for Plantronics CS50 Wireless Headset - I can hear the person on the other end when the configuration dial is set to 1,2 or 3. But th other person cannot hear me. When I set the dial to 4, others...
The following is a cut from Plantronics web site. I hope it helps, It's just possible you have missed a setting, such as the mute switch.
The CS50 has both transmit (how you are heard) and Receive (how you hear) controls on the unit itself.
The Master Transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
The Master Receive setting is on the back of the base (below the picture of the microphone) there is a 1234 switch 1 being the highest setting and 4 being the lowest setting. You can fine tune this setting by using the volume control on the headset itself. This is the rocker volume wheel on the back of the headset (opposite of the microphone).
The headset volume control also doubles as a mute switch if you press it in, instead of rocking it back and forth.
There are also configuration settings on the left hand side of the base. This is a dark grey dial with a 1234 on it. There are notches to the right of this dial. Whatever number is lined up with the notches it what setting you are on.
This needs to be set to the clearest setting.
There is a silver button on the headset itself which is your “Talk button”. This is what you press to use the headset and or transfer the call from the headset back to the hand receiver.
There is also a switch on the right hand side of the base which is your the IntelliStand feature.
When the CS50 is used in conjunction with the HL10 handset lifer you can enable the IntelliStand feature.
The IntelliStand feature senses when the headset has been removed or placed into the CS50 base unit which automatically activates the Handset Lifter and enabling headset/handset mode to answer or end the call.
There is a switch towards the bottom on the right side of the base unit that will switch the IntelliStand feature On and Off.
Apr 11, 2010 | Plantronics PL-CS50 Professional Headset
Can't receive incoming calls, make outgoing ones either.
Always start with taking the battery out. If it continues then you probably have a bad mic & need to have it replaced.
Apr 18, 2009 | Cell Phones
Can't hear caller but caller can hear me except on speakerphone
Take the phone to a mobile reapir center and hvae them replaced teh ear piece and also the speaker.
Oct 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
When i call someone or they call me i can t hear them
Your Internal speakers are on their way out, send the phone into its manufactorer, and they will mail you a brand new one.
Jul 06, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
Other callers hear random beeping during call
The beeping sounds is not the phone's fault I guess, I guess it is the SIM card's fault. Try changing your SIM card to a new one from your service provider. Also buy a new battery from Cell phone companies, please do not buy the Made in China batteries with names different than Motorola, just buy the ones with the Motorola sign.
Hope this helps!
Nicholas
Jan 26, 2008 | Motorola Mobility RAZR V3
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
