Does not spin clothes dry - Washing Machines
  • CrazyJames May 11, 2010
    Is your machine not spinning at all or is it spinning but not enough to remove most of the water?
    Novelist:
  • 195 Answers
Run the washer empty on the lowest water level. Cold will save energy. Watch it fill, close the lid, stay there. Don't advance the timer no matter how tempting as this could skip a program interval. When you hear the water draining listen for a sound change and open the top and see if it drained completely -- pumped out empty. Close the lid so the cycle can continue. During the spin cycle open the lid. See if the drum was really turning fast -- it will be slowing down as soon as you open the lid because that stops the motor. If everything seems normal, then the problem may be transmission or belt slipping under load. Do you have the problem only on large loads? If the spin speed is slow during the test then the transmission is not shifting in to high, controlled by a solenoid. Check the solenoid for power during the spin cycle. Operate the washer on blocks or outside on saw horses to see full function of underneath parts and have access to electrical wires for testing. Use precautions testing and plug into a GFCI. Take your car battery jumper cables and clamp to a water pipe ground and to the underneath frame where the motor mounts. This should keep you from getting electricuted standing in water and holding a test meter.
Posted on Dec 12, 2009
SOURCE:
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
How to more dry after completed washing
A washing machine does not really dry clothes. All it does is that it helps remove most but not all water from the clothes by spinning the clothes at a very high speed and the water comes out because of centrifugal force.
To further dry the clothes, you need to buy a clothes dryer. This machine has a heater inside that actually dries the clothes while keep it spinning at a slow speed.
Usually the company that made your washing machine will also have a dryer in the product portfolio.
Hope that helps
Feb 22, 2015 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Aug 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirlpool LSR7010PQ2 can't spin dry, clothes still wet
If it was spinning slow before the total failure It would be your clutch ,Check your lid switch.
Apr 24, 2009 | Washing Machines
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
