Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a model 110.81375130 Kenmore washer that is making a grinding noise during wash cycle. I already replaced the agitator shoes (similar to agitator dogs on other models). The bottom agitator is only turning in one direction. It looks like the auger agitator teeth on the inside might be worn. If it's not that what else could it be?
    Scholar:
  • 66 Answers
A grinding noise from a washer more often than not means that your motor coupling is worn or broken. The coupling is a small plastic and rubber piece between the motor and the transmission. Not too difficult to replace yourself and very inexpensive. If it is the coupling you may see bits of rubber beneath the machine. If you look up underneath the machine it will be obvious of the coupling is your issue. If not I would recommend calling a licensed repairman to check it out.
Posted on Dec 12, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Whirlpool ETW4100SQ washer. Unit stopped agitating, grinding noise appeared. Tub is loose, agitator is free, was able to empty the drum.
while your washer will draining, in addation to the noise during the agitate cycle is it making a similar noise during the drain/spin cycle?
if that is the case the motor coupler is broken
i have attached a youtube video that will show you step by step how to replace the coupler
http://youtu.be/9K1KHEogf3c
the part number indicated in that video is the exact part number for the coupler
GOOD LUCK,
GENE
Jul 26, 2011 | Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
145 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
