Question about LG Shine KE970 Cellular Phone
Please help 'wireless off' is displayed on screen - unable to connect to network.
  • joannie68 Feb 24, 2008
    On our ke970, the message "wireless off" is displayed. We've tried powering off and on, setting phone on flight mode but nothing has helped. the phone worked for about 12 hours until my daughter traveled to another area about 1 1/2 hours away.
Go to settings and then to filight mode. see if the flight mode is turned on. mine wasn't, but I still had the "wireless off" written on the screen. I turned it on and off again, and the network appeard. hope this will help you.
Posted on Jan 30, 2008
    New Friend:
  • 4 Answers
Menu-Settings-Reset
The problem appears when the USB connection is set to MASS STORAGE instead of DATA SERVICE and the USB cable is disconected without SAFELY REMOVE action from the computer.
Posted on Oct 15, 2013
Thanks fixed the prob!
Posted on Feb 16, 2008
After downloading the disk, my computer is unable to connect to the Belkin router.
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 15, 2013 | Computers & Internet
I want to connect to internet using this unit please help me
  • Figure 1
    The strongest local wireless network connection
    is displayed on the N95's Active standby screen. In this case the phone has found a network called 'mat'
  • Figure 2
    To search for more WLAN connections, click Options, highlight Search for WLAN and click Select
  • Figure 3
    To connect to a WLAN network, highlight its name and click Connect
  • Figure 4
    If the wireless network is security-protected, you'll need to enter its hexadecimal WEP key to log on
  • Figure 5
    You can also connect to a WLAN using the WLAN wizard. This can be found in the Tools are of the Main menu
  • Figure 6
    When opened, the WLAN wizard displays a list of the available local wireless networks. Highlight one and click Options to log on
Feb 28, 2011 | Nokia N95 Cellular Phone
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
Cant get online
Before you can go online on the PS3, there is need for you to have either a wireless lan network or a wired network with an ethernet cable.
If you are using a wireless network, here is how you go about it
  1. Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.
  2. Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu.
  3. Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.
  4. Select "Easy" on the next screen that asks what type of installation you want to use.
  5. Select "Wireless" when it asks you what type of Internet connection you have.
  6. Select "Scan" on the next screen.The system will search for all available Internet connections in the area.
  7. Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.
  8. Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen.
If you are using a wired connection. just go over the same steps but select the wired connection instead of the wireless connection.
Hope this was helpful? Please comment for more information.
Jan 21, 2011 | Sony Playstation 3 (PS3) Console
Cant connect Xbox 360 to this wireless router
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Linksys WRT160N Wireless Router
Suddenly today after working for a couple of years all the lights are on solid and my wireless laptops can not find the router
To connect to your wireless network using Vista's WLAN Autoconfig, follow these steps:
Step 1:
Right-click this icon 5449-001.png at the bottom-right corner of the screen and select Connect to a network.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE:
If the wireless network name or your SSID is not listed, the SSID Broadcast on the router might be disabled. For instructions on how to connect to the wireless network with the SSID broadcast being disabled, click here.
If the computer is not detecting any signal or is not seeing any wireless network, change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless connection even if the wireless security is disabled on your router. If you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing Unable to connect to a wireless network using WEP in Windows Vista Windows Vista Articles Listing Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router Setting-Up the Wireless Settings on a Router Assigning a Static IP Address on a Wired Computer
Nov 06, 2010 | Linksys WRT300N Wireless Router
When I try to login through my wireless router it sometimes connects and displays the correct name "toby" for the connection and is fast (54 Mbs); but sometimes it connects and displays the name "access...
You need to set up your computer's wireless connection. Your computer right now sounds like it defaults to connect to either the "toby" or the "access point" networks. There should be an icon on the task bar, at the bottom right of your screen if you are running windows, that displays information on your wireless network connection when you place the cursor over it. The icon looks like a little desktop with some waves coming out of it.
Open up the control panel for your wireless network and disable the auto-connect feature for the "access point" network. This can vary depending on what type of wireless card you have installed.
You will now only find yourself connected to the fast "toby" network.
please rate my solution
Jul 07, 2010 | Linksys Wireless-G Broadband Router
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
LG Shine KE970 Cellular Phone Logo
70 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
